xilinx_zynq_a9_qemu RTEMS6 no console input/output
junkes
junkes at fhi-berlin.mpg.de
Fri Feb 19 08:31:44 UTC 2021
I'll try your suggested approach. Maybe this will bring us closer to the
matter.
In the meantime, with your setup it works great. Only too well ;-)
e.g. ticker.exe restarts itself automatically again and again endlessly.
fileio.exe also endlessly, no input is accepted.
Everything seems to run "too fast". Problem with delays/timing?
Heinz
On 2021-02-19 08:39, Christian MAUDERER wrote:
> Hello Heinz,
> Am 19.02.21 um 07:53 schrieb junkes:
>> Hello Christian,
>> I checked with gdb.
>> start with
>> sudo ~/QEMU/rtems/6/bin/qemu-system-arm -M xilinx-zynq-a9 -S -s -m
>> 256M -no-reboot -serial null -serial mon:stdio -nographic -kernel
>> ./arm-rtems6/c/xilinx_zynq_a9_qemu/testsuites/samples/fileio.exe
>> other terminal:
>> $ ~/QEMU/rtems/6/bin/arm-rtems6-gdb
>> GNU gdb (GDB) 10.1.90.20210205-git
>> For help, type "help".
>> Type "apropos word" to search for commands related to "word"...
>> Reading symbols from
>> ./arm-rtems6/c/xilinx_zynq_a9_qemu/testsuites/samples/fileio.exe...
>> (gdb) target rem localhost:1234
>> Remote debugging using localhost:1234
>> bsp_start_vector_table_end ()
>> at
>> ../../../../../../../../../kernel/c/src/lib/libbsp/arm/xilinx-zynq/../../../../../../bsps/arm/shared/start/start.S:192
>> 192 mov r0, #0
>> (gdb) c
>> Continuing.
>> <---- no output
>> ^C
>> Program received signal SIGINT, Interrupt.
>> bsp_vector_table_begin ()
>> at
>> ../../../../../../../../../kernel/c/src/lib/libbsp/arm/xilinx-zynq/../../../../../../bsps/arm/shared/start/start.S:73
>> 73 ldr pc, .Lhandler_addr_undef
>> (gdb) bt
>> #0 bsp_vector_table_begin ()
>> at
>> #1 0x0010481c in zynq_mmu_config_table ()
>> Backtrace stopped: previous frame identical to this frame (corrupt
>> stack?)
>> (gdb)
> That looks a bit like there has ben either an exception or the code
> hasn't been load. Can you try the following gdb commands:
> # Reset the system and load binary
> monitor system_reset
> load
> # Set some useful breakpoints (maybe you have to skip some libbsd ones)
> b _ARM_Exception_default
> b _ARMV4_Exception_data_abort_default
> b bsp_interrupt_handler_default
> b bsp_reset
> b _Internal_error_Occurred
> b _Terminate
> # run program
> continue
> If you reach one of the breakpoints do a `bt` like you did above.
>> Same behavior on MVME2500 with RTEMS6:
>> VME2500=> run rtems_myTests
>> reading mvme2500.dtb
>> 12363 bytes read in 13 ms (928.7 KiB/s)
>> Speed: 1000, full duplex
>> Using eTSEC1 device
>> TFTP from server 141.14.128.9; our IP address is 141.14.128.89
>> Filename 'ticker.img'.
>> Load address: 0x10000000
>> Loading: #####
>> 6.4 MiB/s
>> done
>> Bytes transferred = 60182 (eb16 hex)
>> WARNING: adjusting available memory to 30000000
>> ## Booting kernel from Legacy Image at 10000000 ...
>> Image Name: RTEMS
>> Created: 2021-02-18 20:18:21 UTC
>> Image Type: PowerPC Linux Kernel Image (gzip compressed)
>> Data Size: 60118 Bytes = 58.7 KiB
>> Load Address: 00004000
>> Entry Point: 00004000
>> Verifying Checksum ... OK
>> ## Flattened Device Tree blob at 20000000
>> Booting using the fdt blob at 0x20000000
>> Uncompressing Kernel Image ... OK
>> Loading Device Tree to 03ff9000, end 03fff04a ... OK
>> no further output ...
> That's odd. Especially because it is an entirely different target.
> Best regards
> Christian
>> Will now try your install target ...
>> Heinz
>> On 2021-02-18 22:28, Christian Mauderer wrote:
>>> Hello Heinz,
>>> On 18/02/2021 21:38, junkes wrote:
>>>> Hallo Christian,
>>>> thank you for testing. This is "my procedure":
>>> hm. There doesn't seem to be a big difference to mine. If you are
>>> interested, take a look at the install target in the Makefile in:
>>> https://gitlab.com/c-mauderer/rtems-simulation-environment
>>> It's basically just building the same stuff. Differences:
>>> I use the waf based build system for the BSP. But that shouldn't
>>> really matter at the moment. But note that you might have to switch
>>> somewhen in the near future because it is planned to remove the old
>>> autoconf / automake based build system.
>>> Beneath that I use a qemu build from the upstream sorces because the
>>> version from RSB doesn't build cleanly on Arch Linux (something about
>>> docs). But I tried it with the binary build by RSB and that works
>>> too.
>>> I'll think a bit about it and let you know when I find something
>>> other
>>> that might be a problem. But at the moment, I'm running out of ideas.
>>> Maybe you can try to attach a gdb to your qemu and see whether the
>>> application runs and only doesn't produce output?
>>> Best regards
>>> Christian
>>>> ### Installation RTEMS6 / EPICS7 (xilinx_zynq_a9_qemu)
>>>> Installation RTEMS6 and EPICS 7 incl. rtems tools, kernel, bsp and
>>>> libbsd
>>>> ubuntu 20.04.1
>>>> **Installing rtems source builder and build rtems-powerpc tools**
>>>> mkdir QEMU
>>>> cd QEMU
>>>> git clone https://github.com/RTEMS/rtems-source-builder.git rsb
>>>> cd rsb
>>>> git checkout master
>>>> git pull
>>>> cd rtems
>>>> ../source-builder/sb-set-builder --prefix=$HOME/QEMU/rtems/6
>>>> 6/rtems-arm
>>>> RTEMS Source Builder - Set Builder, 6 (61dcadee0825)
>>>> Command Line: ../source-builder/sb-set-builder
>>>> --prefix=/home/junkes/QEMU/rtems/6 6/rtems-arm
>>>> Python: 2.7.18 (default, Aug 4 2020, 11:16:42) [GCC 9.3.0]
>>>> Build Set: 6/rtems-arm
>>>> Build Set: 6/rtems-autotools.bset
>>>> Build Set: 6/rtems-autotools-internal.bset
>>>> config: tools/rtems-autoconf-2.69-1.cfg
>>>> package: autoconf-2.69-x86_64-linux-gnu-1
>>>> script: 1: #!/bin/sh
>>>> script: 2: # ___build_pre as set up in defaults.py
>>>> script: 3: # Save the original path away.
>>>> script: 4: export SB_ORIG_PATH=${PATH}
>>>> script: 5: # Directories
>>>> script: 6: SB_PREFIX="/home/junkes/QEMU/rtems/6"
>>>> script: 7: SB_PREFIX_CLEAN=$(echo "/home/junkes/QEMU/rtems/6" |
>>>> /bin/sed -e 's/^\///')
>>>> script: 8: SB_SOURCE_DIR="/home/junkes/QEMU/rsb/rtems/sources"
>>>> script: 9:
>>>> SB_BUILD_DIR="/home/junkes/QEMU/rsb/rtems/build/autoconf-2.69-x86_64-linux-gnu-1"
>>>> script: 10: # host == build, use build; host != build, host uses
>>>> host and build uses build
>>>> installing: expat-2.1.0-x86_64-linux-gnu-1 ->
>>>> installing: gmp-6.1.0-x86_64-linux-gnu-1 ->
>>>> installing: arm-rtems6-gdb-e1a808d-x86_64-linux-gnu-1 ->
>>>> installing: arm-rtems6-binutils-c0034ac-x86_64-linux-gnu-1 ->
>>>> installing: arm-rtems6-gcc-eb15f76-newlib-d4a756f-x86_64-linux-gnu-1
>>>> -> /home/junkes/QEMU/rtems/6
>>>> installing: rtems-tools-90342feb4dd63d188ce945adfb0a7694a42a65cd-1
>>>> cleaning: expat-2.1.0-x86_64-linux-gnu-1
>>>> cleaning: gmp-6.1.0-x86_64-linux-gnu-1
>>>> cleaning: arm-rtems6-gdb-e1a808d-x86_64-linux-gnu-1
>>>> cleaning: arm-rtems6-binutils-c0034ac-x86_64-linux-gnu-1
>>>> cleaning: arm-rtems6-gcc-eb15f76-newlib-d4a756f-x86_64-linux-gnu-1
>>>> cleaning: rtems-tools-90342feb4dd63d188ce945adfb0a7694a42a65cd-1
>>>> Build Sizes: usage: 9.360GB total: 2.750GB (sources: 796.541MB,
>>>> patches: 66.634KB, installed 1.972GB)
>>>> installing: 6/rtems-arm -> /home/junkes/QEMU/rtems/6
>>>> clean staging: 6/rtems-arm
>>>> Staging Size: 5.291MB
>>>> Build Set: Time 0:34:44.211033
>>>> Build qemu-server:
>>>> --prefix=/home/junkes/QEMU/rtems/6 devel/qemu.bset
>>>> Add to $HOME/.bashrc:
>>>> #RTEMS development
>>>> export RTEMS_VERSION=6
>>>> export RTEMS_ARCH=arm-rtems${RTEMS_VERSION}
>>>> export RTEMS_BSP=xilinx_zynq_a9_qemu
>>>> export RTEMS_ROOT=${HOME}/QEMU/rtems/${RTEMS_VERSION}
>>>> export PATH=${RTEMS_ROOT}/bin:${PATH}
>>>> export
>>>> RTEMS_MAKEFILE_PATH=${RTEMS_ROOT}/${RTEMS_ARCH}/${RTEMS_BSP}
>>>> export
>>>> RTEMS_SHARE_PATH=${RTEMS_ROOT}/share/rtems${RTEMS_VERSION}
>>>> **Installing rtems kernel and bootstrap**
>>>> cd; cd QEMU
>>>> git clone https://github.com/RTEMS/rtems.git kernel
>>>> cd kernel;
>>>> git checkout master
>>>> git pull
>>>> ./bootstrap -c && ./rtems-bootstrap
>>>> output:
>>>> removing automake generated Makefile.in files
>>>> removing configure files
>>>> removing aclocal.m4 files
>>>> RTEMS Bootstrap, 1.0
>>>> 1/119: autoreconf: configure.ac
>>>> 2/119: autoreconf: testsuites/configure.ac
>>>> 3/119: autoreconf: testsuites/smptests/configure.ac
>>>> 4/119: autoreconf: testsuites/fstests/configure.ac
>>>> 5/119: autoreconf: testsuites/ada/configure.ac
>>>> 6/119: autoreconf: testsuites/benchmarks/configure.ac
>>>> 7/119: autoreconf: testsuites/libtests/configure.ac
>>>> 8/119: autoreconf: testsuites/rhealstone/configure.ac
>>>> 9/119: autoreconf: testsuites/psxtests/configure.ac
>>>> 10/119: autoreconf: testsuites/psxtmtests/configure.ac
>>>> 11/119: autoreconf: testsuites/sptests/configure.ac
>>>> 12/119: autoreconf: testsuites/mptests/configure.ac
>>>> 13/119: autoreconf: testsuites/samples/configure.ac
>>>> 14/119: autoreconf: testsuites/tmtests/configure.ac
>>>> 15/119: autoreconf: c/configure.ac
>>>> 110/119: autoreconf:
>>>> c/src/lib/libbsp/powerpc/mvme3100/configure.ac
>>>> 111/119: autoreconf:
>>>> c/src/lib/libbsp/powerpc/haleakala/configure.ac
>>>> 112/119: autoreconf:
>>>> c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac
>>>> 113/119: autoreconf:
>>>> c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac
>>>> 114/119: autoreconf:
>>>> c/src/lib/libbsp/powerpc/qoriq/configure.ac
>>>> 115/119: autoreconf:
>>>> c/src/lib/libbsp/powerpc/gen5200/configure.ac
>>>> 116/119: autoreconf:
>>>> c/src/lib/libbsp/powerpc/qemuppc/configure.ac
>>>> 117/119: autoreconf:
>>>> c/src/lib/libbsp/powerpc/virtex/configure.ac
>>>> 118/119: autoreconf:
>>>> c/src/lib/libbsp/powerpc/virtex4/configure.ac
>>>> 119/119: autoreconf: cpukit/configure.ac
>>>> Bootstrap time: 0:00:27.754820
>>>> cd; cd QEMU
>>>> mkdir -p build/b-xilinx_zynq_a9_qemu/
>>>> cd build/b-xilinx_zynq_a9_qemu/
>>>> ../../kernel/configure --prefix=$HOME/QEMU/rtems/6
>>>> --target=arm-rtems6 --enable-rtemsbsp=xilinx_zynq_a9_qemu
>>>> --enable-posix --enable-c++ --disable-networking --enable-tests
>>>> config.log:
>>>> This file contains any messages produced by compilers while
>>>> running configure, to aid debugging if configure makes a
>>>> mistake.
>>>> It was created by rtems configure 6.0.0, which was
>>>> generated by GNU Autoconf 2.69. Invocation command line was
>>>> $ ../../kernel/configure --prefix=/home/junkes/QEMU/rtems/6
>>>> ## Platform. ##
>>>> hostname = Krikkit
>>>> uname -m = x86_64
>>>> uname -r = 5.8.0-43-generic
>>>> uname -s = Linux
>>>> uname -v = #49~20.04.1-Ubuntu SMP Fri Feb 5 09:57:56 UTC 2021
>>>> /usr/bin/uname -p = x86_64
>>>> /bin/uname -X = unknown
>>>> make -j17 all
>>>> make install
>>>> rtems-libbsd
>>>> cd;cd QEMU
>>>> cd rtems-libbsd
>>>> git remote -v
>>>> origin https://github.com/RTEMS/rtems-libbsd.git (fetch)
>>>> origin https://github.com/RTEMS/rtems-libbsd.git (push)
>>>> git checkout master
>>>> git pull
>>>> git checkout 6-freebsd-12
>>>> git submodule init
>>>> git submodule update rtems_waf
>>>> ./waf configure --prefix=$HOME/QEMU/rtems/6
>>>> --rtems-bsps=arm/xilinx_zynq_a9_qemu --buildset=buildset/default.ini
>>>> ./waf
>>>> ./waf install
>>>> qemu-testing:
>>>> no ouptut and must be killed by other terminal:
>>>> $ qemu-system-arm -no-reboot -serial null -serial mon:stdio -net
>>>> none -nographic -M xilinx-zynq-a9 -m 256M -kernel
>>>> arm-rtems6/c/xilinx_zynq_a9_qemu/testsuites/samples/hello.exe
>>>> qemu-system-arm: warning: nic cadence_gem.0 has no peer
>>>> qemu-system-arm: warning: nic cadence_gem.1 has no peer
>>>> On 2021-02-18 21:10, Christian Mauderer wrote:
>>>>> Hello Heinz,
>>>>> Odd. I just tested it with the current master of rtems, libbsd,
>>>>> rtems
>>>>> source builder and qemu and it worked fine. The only thing that I
>>>>> had
>>>>> to change compared to your command was adding the "-serial null"
>>>>> before the second "-serial mon:stdio". Note that it's "null" and
>>>>> not
>>>>> "none" like for network. I made that mistake when trying to adapt
>>>>> your
>>>>> command line the first time and received no output.
>>>>> Beneath that I have an
>>>>> export QEMU_AUDIO_DRV=none
>>>>> in my script that starts qemu. I'm not sure why and it seems that
>>>>> it
>>>>> is no longer necessary. But maybe you want to try it.
>>>>> If both don't help:
>>>>> Which version of rtems are you using and how do you configure your
>>>>> BSP? Which version of qemu are you using?
>>>>> On 18/02/2021 18:21, Heinz Junkes wrote:
>>>>>> Thanks, unfortunately I also have the same behavior with -serial
>>>>>> null -serial on:stdio.
>>>>>> So I use it with RTEMS5 which worked so far.
>>>>>> I had found this in the mail list and tried it ;-)
>>>>> The patch below seems to be for the xilinx_zynqmp* BSP and not for
>>>>> the
>>>>> xilinx_zynq_a9_qemu.
>>>>> Best regards
>>>>> Christian
>>>>>> Heinz
>>>>>> Qemu's machine definition uses the second UART in the memory map
>>>>>> as the
>>>>>> primary UART. This follows from the hardware itself where the
>>>>>> second
>>>>>> UART in the memory map is UART 0. This switches the tester to
>>>>>> using the
>>>>>> correct UART.
>>>>>> tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini | 2 +-
>>>>>> tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini | 2 +-
>>>>>> 2 files changed, 2 insertions(+), 2 deletions(-)
>>>>>> diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
>>>>>> b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
>>>>>> index 5ff0e86..35869ed 100644
>>>>>> --- a/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
>>>>>> +++ b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
>>>>>> @@ -35,4 +35,4 @@
>>>>>> bsp = xilinx_zynqmp_ilp32
>>>>>> arch = aarch64
>>>>>> tester = %{_rtscripts}/qemu.cfg
>>>>>> -bsp_qemu_opts = %{qemu_opts_base} -serial null -serial mon:stdio
>>>>>> -machine xlnx-zcu102 -m 4096
>>>>>> +bsp_qemu_opts = %{qemu_opts_base} -serial mon:stdio -machine
>>>>>> xlnx-zcu102 -m 4096
>>>>>> diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
>>>>>> b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
>>>>>> index 8db82b6..cd2d268 100644
>>>>>> --- a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
>>>>>> +++ b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
>>>>>> @@ -35,4 +35,4 @@
>>>>>> bsp = xilinx_zynqmp_lp64
>>>>>> arch = aarch64
>>>>>> xlnx-zcu102 -m 4096
>>>>>> _______________________________________________
>>>>>> users mailing list
>>>>>> users at rtems.org
>>>>>> http://lists.rtems.org/mailman/listinfo/users
>>>> users mailing list
>>>> users at rtems.org
> embedded brains GmbH
> Herr Christian MAUDERER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> phone: +49-89-18 94 741 - 18
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
