xilinx_zynq_a9_qemu RTEMS6 no console input/output
Christian MAUDERER
christian.mauderer at embedded-brains.de
Fri Feb 19 07:39:19 UTC 2021
Hello Heinz,
Am 19.02.21 um 07:53 schrieb junkes:
> Hello Christian,
> I checked with gdb.
> start with
> sudo ~/QEMU/rtems/6/bin/qemu-system-arm -M xilinx-zynq-a9 -S -s -m 256M
> -no-reboot -serial null -serial mon:stdio -nographic -kernel
> ./arm-rtems6/c/xilinx_zynq_a9_qemu/testsuites/samples/fileio.exe
> other terminal:
> $ ~/QEMU/rtems/6/bin/arm-rtems6-gdb
> GNU gdb (GDB) 10.1.90.20210205-git
> For help, type "help".
> Type "apropos word" to search for commands related to "word"...
> Reading symbols from
> ./arm-rtems6/c/xilinx_zynq_a9_qemu/testsuites/samples/fileio.exe...
> (gdb) target rem localhost:1234
> Remote debugging using localhost:1234
> bsp_start_vector_table_end ()
> at
> ../../../../../../../../../kernel/c/src/lib/libbsp/arm/xilinx-zynq/../../../../../../bsps/arm/shared/start/start.S:192
> 192 mov r0, #0
> (gdb) c
> Continuing.
> <---- no output
> ^C
> Program received signal SIGINT, Interrupt.
> bsp_vector_table_begin ()
> at
> ../../../../../../../../../kernel/c/src/lib/libbsp/arm/xilinx-zynq/../../../../../../bsps/arm/shared/start/start.S:73
> 73 ldr pc, .Lhandler_addr_undef
> (gdb) bt
> #0 bsp_vector_table_begin ()
> at
> #1 0x0010481c in zynq_mmu_config_table ()
> Backtrace stopped: previous frame identical to this frame (corrupt stack?)
> (gdb)
That looks a bit like there has ben either an exception or the code
hasn't been load. Can you try the following gdb commands:
# Reset the system and load binary
monitor system_reset
load
# Set some useful breakpoints (maybe you have to skip some libbsd ones)
b _ARM_Exception_default
b _ARMV4_Exception_data_abort_default
b bsp_interrupt_handler_default
b bsp_reset
b _Internal_error_Occurred
b _Terminate
# run program
continue
If you reach one of the breakpoints do a `bt` like you did above.
> Same behavior on MVME2500 with RTEMS6:
> VME2500=> run rtems_myTests
> reading mvme2500.dtb
> 12363 bytes read in 13 ms (928.7 KiB/s)
> Speed: 1000, full duplex
> Using eTSEC1 device
> TFTP from server 141.14.128.9; our IP address is 141.14.128.89
> Filename 'ticker.img'.
> Load address: 0x10000000
> Loading: #####
> 6.4 MiB/s
> done
> Bytes transferred = 60182 (eb16 hex)
> WARNING: adjusting available memory to 30000000
> ## Booting kernel from Legacy Image at 10000000 ...
> Image Name: RTEMS
> Created: 2021-02-18 20:18:21 UTC
> Image Type: PowerPC Linux Kernel Image (gzip compressed)
> Data Size: 60118 Bytes = 58.7 KiB
> Load Address: 00004000
> Entry Point: 00004000
> Verifying Checksum ... OK
> ## Flattened Device Tree blob at 20000000
> Booting using the fdt blob at 0x20000000
> Uncompressing Kernel Image ... OK
> Loading Device Tree to 03ff9000, end 03fff04a ... OK
> no further output ...
That's odd. Especially because it is an entirely different target.
Best regards
Christian
> Will now try your install target ...
> Heinz
> On 2021-02-18 22:28, Christian Mauderer wrote:
>> Hello Heinz,
>> On 18/02/2021 21:38, junkes wrote:
>>> Hallo Christian,
>>> thank you for testing. This is "my procedure":
>> hm. There doesn't seem to be a big difference to mine. If you are
>> interested, take a look at the install target in the Makefile in:
>> https://gitlab.com/c-mauderer/rtems-simulation-environment
>> It's basically just building the same stuff. Differences:
>> I use the waf based build system for the BSP. But that shouldn't
>> really matter at the moment. But note that you might have to switch
>> somewhen in the near future because it is planned to remove the old
>> autoconf / automake based build system.
>> Beneath that I use a qemu build from the upstream sorces because the
>> version from RSB doesn't build cleanly on Arch Linux (something about
>> docs). But I tried it with the binary build by RSB and that works too.
>> I'll think a bit about it and let you know when I find something other
>> that might be a problem. But at the moment, I'm running out of ideas.
>> Maybe you can try to attach a gdb to your qemu and see whether the
>> application runs and only doesn't produce output?
>> Best regards
>> Christian
>>> ### Installation RTEMS6 / EPICS7 (xilinx_zynq_a9_qemu)
>>> Installation RTEMS6 and EPICS 7 incl. rtems tools, kernel, bsp and
>>> libbsd
>>> ubuntu 20.04.1
>>> **Installing rtems source builder and build rtems-powerpc tools**
>>> mkdir QEMU
>>> cd QEMU
>>> git clone https://github.com/RTEMS/rtems-source-builder.git rsb
>>> cd rsb
>>> git checkout master
>>> git pull
>>> cd rtems
>>> ../source-builder/sb-set-builder --prefix=$HOME/QEMU/rtems/6
>>> 6/rtems-arm
>>> RTEMS Source Builder - Set Builder, 6 (61dcadee0825)
>>> Command Line: ../source-builder/sb-set-builder
>>> --prefix=/home/junkes/QEMU/rtems/6 6/rtems-arm
>>> Python: 2.7.18 (default, Aug 4 2020, 11:16:42) [GCC 9.3.0]
>>> Build Set: 6/rtems-arm
>>> Build Set: 6/rtems-autotools.bset
>>> Build Set: 6/rtems-autotools-internal.bset
>>> config: tools/rtems-autoconf-2.69-1.cfg
>>> package: autoconf-2.69-x86_64-linux-gnu-1
>>> script: 1: #!/bin/sh
>>> script: 2: # ___build_pre as set up in defaults.py
>>> script: 3: # Save the original path away.
>>> script: 4: export SB_ORIG_PATH=${PATH}
>>> script: 5: # Directories
>>> script: 6: SB_PREFIX="/home/junkes/QEMU/rtems/6"
>>> script: 7: SB_PREFIX_CLEAN=$(echo "/home/junkes/QEMU/rtems/6" |
>>> /bin/sed -e 's/^\///')
>>> script: 8: SB_SOURCE_DIR="/home/junkes/QEMU/rsb/rtems/sources"
>>> script: 9:
>>> SB_BUILD_DIR="/home/junkes/QEMU/rsb/rtems/build/autoconf-2.69-x86_64-linux-gnu-1"
>>> script: 10: # host == build, use build; host != build, host uses host
>>> and build uses build
>>> installing: expat-2.1.0-x86_64-linux-gnu-1 -> /home/junkes/QEMU/rtems/6
>>> installing: gmp-6.1.0-x86_64-linux-gnu-1 -> /home/junkes/QEMU/rtems/6
>>> installing: arm-rtems6-gdb-e1a808d-x86_64-linux-gnu-1 ->
>>> installing: arm-rtems6-binutils-c0034ac-x86_64-linux-gnu-1 ->
>>> installing: arm-rtems6-gcc-eb15f76-newlib-d4a756f-x86_64-linux-gnu-1
>>> installing: rtems-tools-90342feb4dd63d188ce945adfb0a7694a42a65cd-1 ->
>>> cleaning: expat-2.1.0-x86_64-linux-gnu-1
>>> cleaning: gmp-6.1.0-x86_64-linux-gnu-1
>>> cleaning: arm-rtems6-gdb-e1a808d-x86_64-linux-gnu-1
>>> cleaning: arm-rtems6-binutils-c0034ac-x86_64-linux-gnu-1
>>> cleaning: arm-rtems6-gcc-eb15f76-newlib-d4a756f-x86_64-linux-gnu-1
>>> cleaning: rtems-tools-90342feb4dd63d188ce945adfb0a7694a42a65cd-1
>>> Build Sizes: usage: 9.360GB total: 2.750GB (sources: 796.541MB,
>>> patches: 66.634KB, installed 1.972GB)
>>> installing: 6/rtems-arm -> /home/junkes/QEMU/rtems/6
>>> clean staging: 6/rtems-arm
>>> Staging Size: 5.291MB
>>> Build Set: Time 0:34:44.211033
>>> Build qemu-server:
>>> --prefix=/home/junkes/QEMU/rtems/6 devel/qemu.bset
>>> Add to $HOME/.bashrc:
>>> #RTEMS development
>>> export RTEMS_VERSION=6
>>> export RTEMS_ARCH=arm-rtems${RTEMS_VERSION}
>>> export RTEMS_BSP=xilinx_zynq_a9_qemu
>>> export RTEMS_ROOT=${HOME}/QEMU/rtems/${RTEMS_VERSION}
>>> export PATH=${RTEMS_ROOT}/bin:${PATH}
>>> export RTEMS_MAKEFILE_PATH=${RTEMS_ROOT}/${RTEMS_ARCH}/${RTEMS_BSP}
>>> export RTEMS_SHARE_PATH=${RTEMS_ROOT}/share/rtems${RTEMS_VERSION}
>>> **Installing rtems kernel and bootstrap**
>>> cd; cd QEMU
>>> git clone https://github.com/RTEMS/rtems.git kernel
>>> cd kernel;
>>> git checkout master
>>> git pull
>>> ./bootstrap -c && ./rtems-bootstrap
>>> output:
>>> removing automake generated Makefile.in files
>>> removing configure files
>>> removing aclocal.m4 files
>>> RTEMS Bootstrap, 1.0
>>> 1/119: autoreconf: configure.ac
>>> 2/119: autoreconf: testsuites/configure.ac
>>> 3/119: autoreconf: testsuites/smptests/configure.ac
>>> 4/119: autoreconf: testsuites/fstests/configure.ac
>>> 5/119: autoreconf: testsuites/ada/configure.ac
>>> 6/119: autoreconf: testsuites/benchmarks/configure.ac
>>> 7/119: autoreconf: testsuites/libtests/configure.ac
>>> 8/119: autoreconf: testsuites/rhealstone/configure.ac
>>> 9/119: autoreconf: testsuites/psxtests/configure.ac
>>> 10/119: autoreconf: testsuites/psxtmtests/configure.ac
>>> 11/119: autoreconf: testsuites/sptests/configure.ac
>>> 12/119: autoreconf: testsuites/mptests/configure.ac
>>> 13/119: autoreconf: testsuites/samples/configure.ac
>>> 14/119: autoreconf: testsuites/tmtests/configure.ac
>>> 15/119: autoreconf: c/configure.ac
>>> 110/119: autoreconf: c/src/lib/libbsp/powerpc/mvme3100/configure.ac
>>> 111/119: autoreconf:
>>> c/src/lib/libbsp/powerpc/haleakala/configure.ac
>>> 112/119: autoreconf:
>>> c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac
>>> 113/119: autoreconf:
>>> c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac
>>> 114/119: autoreconf: c/src/lib/libbsp/powerpc/qoriq/configure.ac
>>> 115/119: autoreconf: c/src/lib/libbsp/powerpc/gen5200/configure.ac
>>> 116/119: autoreconf: c/src/lib/libbsp/powerpc/qemuppc/configure.ac
>>> 117/119: autoreconf: c/src/lib/libbsp/powerpc/virtex/configure.ac
>>> 118/119: autoreconf: c/src/lib/libbsp/powerpc/virtex4/configure.ac
>>> 119/119: autoreconf: cpukit/configure.ac
>>> Bootstrap time: 0:00:27.754820
>>> cd; cd QEMU
>>> mkdir -p build/b-xilinx_zynq_a9_qemu/
>>> cd build/b-xilinx_zynq_a9_qemu/
>>> ../../kernel/configure --prefix=$HOME/QEMU/rtems/6
>>> --target=arm-rtems6 --enable-rtemsbsp=xilinx_zynq_a9_qemu
>>> --enable-posix --enable-c++ --disable-networking --enable-tests
>>> config.log:
>>> This file contains any messages produced by compilers while
>>> running configure, to aid debugging if configure makes a mistake.
>>> It was created by rtems configure 6.0.0, which was
>>> generated by GNU Autoconf 2.69. Invocation command line was
>>> $ ../../kernel/configure --prefix=/home/junkes/QEMU/rtems/6
>>> ## Platform. ##
>>> hostname = Krikkit
>>> uname -m = x86_64
>>> uname -r = 5.8.0-43-generic
>>> uname -s = Linux
>>> uname -v = #49~20.04.1-Ubuntu SMP Fri Feb 5 09:57:56 UTC 2021
>>> /usr/bin/uname -p = x86_64
>>> /bin/uname -X = unknown
>>> make -j17 all
>>> make install
>>> rtems-libbsd
>>> cd;cd QEMU
>>> cd rtems-libbsd
>>> git remote -v
>>> origin https://github.com/RTEMS/rtems-libbsd.git (fetch)
>>> origin https://github.com/RTEMS/rtems-libbsd.git (push)
>>> git checkout master
>>> git pull
>>> git checkout 6-freebsd-12
>>> git submodule init
>>> git submodule update rtems_waf
>>> ./waf configure --prefix=$HOME/QEMU/rtems/6
>>> --rtems-bsps=arm/xilinx_zynq_a9_qemu --buildset=buildset/default.ini
>>> ./waf
>>> ./waf install
>>> qemu-testing:
>>> no ouptut and must be killed by other terminal:
>>> $ qemu-system-arm -no-reboot -serial null -serial mon:stdio -net none
>>> -nographic -M xilinx-zynq-a9 -m 256M -kernel
>>> arm-rtems6/c/xilinx_zynq_a9_qemu/testsuites/samples/hello.exe
>>> qemu-system-arm: warning: nic cadence_gem.0 has no peer
>>> qemu-system-arm: warning: nic cadence_gem.1 has no peer
>>> On 2021-02-18 21:10, Christian Mauderer wrote:
>>>> Hello Heinz,
>>>> Odd. I just tested it with the current master of rtems, libbsd, rtems
>>>> source builder and qemu and it worked fine. The only thing that I had
>>>> to change compared to your command was adding the "-serial null"
>>>> before the second "-serial mon:stdio". Note that it's "null" and not
>>>> "none" like for network. I made that mistake when trying to adapt your
>>>> command line the first time and received no output.
>>>> Beneath that I have an
>>>> export QEMU_AUDIO_DRV=none
>>>> in my script that starts qemu. I'm not sure why and it seems that it
>>>> is no longer necessary. But maybe you want to try it.
>>>> If both don't help:
>>>> Which version of rtems are you using and how do you configure your
>>>> BSP? Which version of qemu are you using?
>>>> On 18/02/2021 18:21, Heinz Junkes wrote:
>>>>> Thanks, unfortunately I also have the same behavior with -serial
>>>>> null -serial on:stdio.
>>>>> So I use it with RTEMS5 which worked so far.
>>>>> I had found this in the mail list and tried it ;-)
>>>> The patch below seems to be for the xilinx_zynqmp* BSP and not for the
>>>> xilinx_zynq_a9_qemu.
>>>> Best regards
>>>> Christian
>>>>> Heinz
>>>>> Qemu's machine definition uses the second UART in the memory map as
>>>>> the
>>>>> primary UART. This follows from the hardware itself where the second
>>>>> UART in the memory map is UART 0. This switches the tester to using
>>>>> the
>>>>> correct UART.
>>>>> tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini | 2 +-
>>>>> tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini | 2 +-
>>>>> 2 files changed, 2 insertions(+), 2 deletions(-)
>>>>> diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
>>>>> b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
>>>>> index 5ff0e86..35869ed 100644
>>>>> --- a/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
>>>>> +++ b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
>>>>> @@ -35,4 +35,4 @@
>>>>> bsp = xilinx_zynqmp_ilp32
>>>>> arch = aarch64
>>>>> tester = %{_rtscripts}/qemu.cfg
>>>>> -bsp_qemu_opts = %{qemu_opts_base} -serial null -serial mon:stdio
>>>>> -machine xlnx-zcu102 -m 4096
>>>>> +bsp_qemu_opts = %{qemu_opts_base} -serial mon:stdio -machine
>>>>> xlnx-zcu102 -m 4096
>>>>> diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
>>>>> b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
>>>>> index 8db82b6..cd2d268 100644
>>>>> --- a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
>>>>> +++ b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
>>>>> @@ -35,4 +35,4 @@
>>>>> bsp = xilinx_zynqmp_lp64
>>>>> arch = aarch64
>>>>> xlnx-zcu102 -m 4096
>>>>> _______________________________________________
>>>>> users mailing list
>>>>> users at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/users
>>> users mailing list
>>> users at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
