xilinx_zynq_a9_qemu RTEMS6 no console input/output
Heinz Junkes junkes at fhi-berlin.mpg.de
Fri Feb 19 08:57:14 UTC 2021
Sorry, I should have seen…
Yes, it works as you wrote.
Now I just need to clarify the timing problem with fileio keyboard input....
Vielen, vielen Dank für Deine Hilfe,
Heinz
> On 19. Feb 2021, at 09:45, Christian MAUDERER <christian.mauderer at embedded-brains.de> wrote:
> If you start the script just like it is, it assumes that you want to connect a gdb. In that case qemu is started with parameters that restart after the application terminates.
> If you want to run an application without gdb, you have to pass "-p 0" to the script. This disables the gdb port and sets the -no-reboot option of qemu.
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20210219/d4edb7f6/attachment-0001.bin>
