xilinx_zynq_a9_qemu RTEMS6 no console input/output
Christian MAUDERER
christian.mauderer at embedded-brains.de
Fri Feb 19 09:02:24 UTC 2021
Hello Heinz,
Am 19.02.21 um 09:57 schrieb Heinz Junkes:
> Sorry, I should have seen…
> Yes, it works as you wrote.
> Now I just need to clarify the timing problem with fileio keyboard input....
Like I said: I would start at the CLOCK_DRIVER_USE_FAST_IDLE option. If
you use my environment, the config.ini is generated and edited
automatically. So you either have to change that or add a lin in the
build_bsp function that changes the value.
> Vielen, vielen Dank für Deine Hilfe,
Kein Problem.
Christian
> Heinz
>> On 19. Feb 2021, at 09:45, Christian MAUDERER <christian.mauderer at embedded-brains.de> wrote:
>> If you start the script just like it is, it assumes that you want to connect a gdb. In that case qemu is started with parameters that restart after the application terminates.
>> If you want to run an application without gdb, you have to pass "-p 0" to the script. This disables the gdb port and sets the -no-reboot option of qemu.
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
