xilinx_zynq_a9_qemu RTEMS6 no console input/output
Heinz Junkes junkes at fhi-berlin.mpg.de
Fri Feb 19 12:01:15 UTC 2021
Unfortunately, the option is set to "False" by default.
CLOCK_DRIVER_USE_FAST_IDLE = False
Heinz
> On 19. Feb 2021, at 09:45, Christian MAUDERER <christian.mauderer at embedded-brains.de> wrote:
> I think some of the simulator BSPs have an option that enable some kind of time laps as soon as the idle routine is reached.
> In the new waf build system it's the option CLOCK_DRIVER_USE_FAST_IDLE in the config.ini.
> I'm not 100% sure how it would have been disabled in the old build system. I assume you have to pass CLOCK_DRIVER_USE_FAST_IDLE=0 to the configure call.
> Best regards
> Christian
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20210219/f0f11884/attachment.bin>
