xilinx_zynq_a9_qemu RTEMS6 no console input/output
Christian MAUDERER christian.mauderer at embedded-brains.de
Fri Feb 19 12:21:22 UTC 2021
Am 19.02.21 um 13:06 schrieb Heinz Junkes:
> Sorry. The settings for several targets are in the defaults.
> and for ARM-Cortex-A9 the default value is
> CLOCK_DRIVER_USE_FAST_IDLE = True
That should be dependent on the BSP. Most likely for most simulator BSPs
it's True.
Best regards
Christian
> Sorry for the noise ….
> Heinz
>> On 19. Feb 2021, at 09:45, Christian MAUDERER <christian.mauderer at embedded-brains.de> wrote:
>> I think some of the simulator BSPs have an option that enable some kind of time laps as soon as the idle routine is reached.
>> In the new waf build system it's the option CLOCK_DRIVER_USE_FAST_IDLE in the config.ini.
>> I'm not 100% sure how it would have been disabled in the old build system. I assume you have to pass CLOCK_DRIVER_USE_FAST_IDLE=0 to the configure call.
>> Best regards
>> Christian
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
