MVME2500 (qoriq_e500) no longer boots with RTEMS6
Heinz Junkes junkes at fhi-berlin.mpg.de
Fri Feb 19 16:30:04 UTC 2021
When I use the kernel from RTEMS6 my MVME2500 (qoriq_e500)
does not boot anymore and hangs:
VME2500=> run rtems_myTests
reading mvme2500.dtb
12363 bytes read in 13 ms (928.7 KiB/s)
Speed: 1000, full duplex
Using eTSEC1 device
TFTP from server 141.14.128.9; our IP address is 141.14.128.89
Filename 'ticker.img'.
Load address: 0x10000000
Loading: #####
        6.4 MiB/s
done
Bytes transferred = 60182 (eb16 hex)
WARNING: adjusting available memory to 30000000
## Booting kernel from Legacy Image at 10000000 ...
  Image Name:   RTEMS
  Created:      2021-02-18  20:18:21 UTC
  Image Type:   PowerPC Linux Kernel Image (gzip compressed)
  Data Size:    60118 Bytes = 58.7 KiB
  Load Address: 00004000
  Entry Point:  00004000
  Verifying Checksum ... OK
## Flattened Device Tree blob at 20000000
  Booting using the fdt blob at 0x20000000
  Uncompressing Kernel Image ... OK
  Loading Device Tree to 03ff9000, end 03fff04a ... OK
no more output
Heinz
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20210219/e5645387/attachment.bin>
