xilinx_zynq_a9_qemu with RTEMS 6 keyboard input is ignored
junkes junkes at fhi-berlin.mpg.de
Fri Feb 19 20:10:09 UTC 2021
running test programs with keyboard input. Is ignored on
xilinx_zynq_a9_qemu
qemu-system-arm -no-reboot -net none -serial null -serial mon:stdio -M
xilinx-zynq-a9 -m 256M -nographic -kernel
./external/rtems/build/arm/xilinx_zynq_a9_qemu/testsuites/samples/fileio.exe
qemu-system-arm: warning: nic cadence_gem.0 has no peer
qemu-system-arm: warning: nic cadence_gem.1 has no peer
*** BEGIN OF TEST FILE I/O ***
*** TEST VERSION: 6.0.0.407e351e11d3c4d0db8eb2d23ae2554f35f31697
*** TEST STATE: USER_INPUT
*** TEST BUILD:
*** TEST TOOLS: 10.2.1 20210205 (RTEMS 6, RSB
61dcadee0825867ebe51f9f367430ef75b8fe9c0-modified, Newlib d4a756f)
Press any key to start file I/O sample (20s remaining)
Press any key to start file I/O sample (19s remaining)
Press any key to start file I/O sample (18s remaining)
Press any key to start file I/O sample (17s remaining)
Press any key to start file I/O sample (16s remaining)
Press any key to start file I/O sample (15s remaining)
Press any key to start file I/O sample (14s remaining)
Press any key to start file I/O sample (13s remaining)
Press any key to start file I/O sample (12s remaining)
Press any key to start file I/O sample (11s remaining)
Press any key to start file I/O sample (10s remaining)
Press any key to start file I/O sample (9s remaining)
