MVME2500 (qoriq_e500) no longer boots with RTEMS6
Christian Mauderer oss at c-mauderer.de
Fri Feb 19 21:13:57 UTC 2021
On 19/02/2021 17:30, Heinz Junkes wrote:
> When I use the kernel from RTEMS6 my MVME2500 (qoriq_e500)
> does not boot anymore and hangs:
> VME2500=> run rtems_myTests
> reading mvme2500.dtb
> 12363 bytes read in 13 ms (928.7 KiB/s)
> Speed: 1000, full duplex
> Using eTSEC1 device
> TFTP from server 141.14.128.9; our IP address is 141.14.128.89
> Filename 'ticker.img'.
> Load address: 0x10000000
> Loading: #####
>          6.4 MiB/s
> done
> Bytes transferred = 60182 (eb16 hex)
> WARNING: adjusting available memory to 30000000
> ## Booting kernel from Legacy Image at 10000000 ...
>    Image Name:   RTEMS
>    Created:      2021-02-18  20:18:21 UTC
>    Image Type:   PowerPC Linux Kernel Image (gzip compressed)
>    Data Size:    60118 Bytes = 58.7 KiB
>    Load Address: 00004000
>    Entry Point:  00004000
>    Verifying Checksum ... OK
> ## Flattened Device Tree blob at 20000000
>    Booting using the fdt blob at 0x20000000
>    Uncompressing Kernel Image ... OK
>    Loading Device Tree to 03ff9000, end 03fff04a ... OK
> no more output
Just a wild guess: Can you compare the addresses of the binaries. Maybe
for some reason a wrong linkcmds is used. arm-rtems6-objdump -h app.exe
should give you the relevant information.
> Heinz
> users mailing list
> users at rtems.org
