Offline download of sources fails
Ida Delphine idadelm at gmail.com
Thu Mar 11 04:34:00 UTC 2021
Hello again,
So I started over and downloaded all the required packages for my host
(Ubuntu 20.04) and still have offline download issues...
Please take a look at the error message:
RTEMS Source Builder - Set Builder, 6 (fe2d13b6daf3)
Build Set: 6/rtems-sparc
Build Set: 6/rtems-autotools.bset
Build Set: 6/rtems-autotools-internal.bset
config: tools/rtems-autoconf-2.69-1.cfg
config: tools/rtems-automake-1.12.6-1.cfg
Build Sizes: usage: 0.000B total: 19.014KB (sources: 0.000B, patches:
19.014KB, installed 0.000B)
Build Set: Time 0:00:00.933172
Build Set: 6/rtems-autotools-base.bset
Build Set: Time 0:00:00.840448
Build Set: Time 0:00:01.777350
config: devel/expat-2.1.0-1.cfg
package: expat-2.1.0-x86_64-linux-gnu-1
Creating source directory: sources
download:
https://github.com/libexpat/libexpat/releases/download/R_2_1_0/expat-2.1.0.tar.gz
-> sources/expat-2.1.0.tar.gz
 redirect:
https://github-releases.githubusercontent.com/80314213/0186bc60-b675-11e7-83c0-13aced4...<see
log>
downloading: sources/expat-2.1.0.tar.gz - 549.4kB of 549.4kB (100%)
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.txt
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.xml
config: devel/gmp-6.1.0.cfg
package: gmp-6.1.0-x86_64-linux-gnu-1
download: https://gcc.gnu.org/pub/gcc/infrastructure/gmp-6.1.0.tar.bz2 ->
sources/gmp-6.1.0.tar.bz2
downloading: sources/gmp-6.1.0.tar.bz2 - 2.3MB of 2.3MB (100%)
reporting: devel/gmp-6.1.0.cfg -> gmp-6.1.0-x86_64-linux-gnu-1.txt
reporting: devel/gmp-6.1.0.cfg -> gmp-6.1.0-x86_64-linux-gnu-1.xml
config: tools/rtems-gdb-10.cfg
error: shell macro failed:
/home/idadel/quick-start/src/rsb/source-builder/sb/rtems-build-dep -c gcc
 -l : 2: error: no library (-l) provided
Build FAILED
Build Set: Time 0:00:12.713688
Build FAILED
Also for some reason when I run "sb-check" it tells me "command not found"
Cheers,
Ida.
On Thu, Mar 11, 2021 at 12:30 AM Chris Johns <chrisj at rtems.org> wrote:
> On 11/3/21 8:23 am, Michael Davidsaver wrote:
> > On 3/10/21 10:55 AM, Chris Johns wrote:
> >> Also have a look at the command sb-get-sources. It will fetch the
> source and
> >> patches for all hosts and architectures.
> > Neat.  I've been wishing for something like this as I'd like to archive
> full
> > source along with toolchain builds.
> The patches and sources directories hold everything.
> > Would it handle something like an
> > arch/bsp specific patches to rtems-kernel or rtems-libbsd?  (assuming
> there
> > can be such things)
> If the RSB is configured to download a patch this tool will download it.
> The
> kernel and libbsd tend to be built based on a commit in their respective
> repos
> the RSB downloads a tarball of the source that is uses.
> Note, the RSB supports a released mode that is controlled by the VERSION
> file in
> the root directory of the RSB. This can be used to deploy source locally.
> The
> release scripts ...
> https://git.rtems.org/rtems-release/tree/rtems-release-sources
> ... do this when creating a release.
> >> $ ../source-builder/sb-get-sources --tar 5/rtems-powerpc 5/rtems-i386
> 5/rtems-arm 5/rtems-kernel 5/rtems-libbsd
> >> RTEMS Source Builder - Get Sources, 5 (803d42cda7b3)
> >> Build Set: 5/rtems-i386 for win32
> >> error: 5/rtems-i386:5: %patch duplicate add:
> https://devel.rtems.org/raw-attachment/ticket/2830/gcc-7.5.0-i386march-1.diff
> >> Build Set: Time 0:00:00.000236
> >> Build FAILED
> > I guess the recent march patch breaks this somehow?
> The patch link looks fine and I can download it with my browser. I wonder
> if
> this is a Windows thing?
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20210311/88019e9e/attachment.html>
