Offline download of sources fails
Thu Mar 11 05:07:06 UTC 2021
On 11/3/21 3:34 pm, Ida Delphine wrote:
> Hello again,
> So I started over and downloaded all the required packages for my host (Ubuntu
> 20.04) and still have offline download issues...
> Please take a look at the error message:
> RTEMS Source Builder - Set Builder, 6 (fe2d13b6daf3)
> Build Set: 6/rtems-sparc
> Build Set: 6/rtems-autotools.bset
> Build Set: 6/rtems-autotools-internal.bset
> config: tools/rtems-autoconf-2.69-1.cfg
> config: tools/rtems-automake-1.12.6-1.cfg
> Build Sizes: usage: 0.000B total: 19.014KB (sources: 0.000B, patches: 19.014KB,
> installed 0.000B)
> Build Set: Time 0:00:00.933172
> Build Set: 6/rtems-autotools-base.bset
> installed 0.000B)
> Build Set: Time 0:00:00.840448
> Build Set: Time 0:00:01.777350
> config: devel/expat-2.1.0-1.cfg
> package: expat-2.1.0-x86_64-linux-gnu-1
> Creating source directory: sources
> download:
> https://github.com/libexpat/libexpat/releases/download/R_2_1_0/expat-2.1.0.tar.gz <https://github.com/libexpat/libexpat/releases/download/R_2_1_0/expat-2.1.0.tar.gz>
> -> sources/expat-2.1.0.tar.gz
>  redirect:
> https://github-releases.githubusercontent.com/80314213/0186bc60-b675-11e7-83c0-13aced4..
> <https://github-releases.githubusercontent.com/80314213/0186bc60-b675-11e7-83c0-13aced4..>.<see
> log>
> downloading: sources/expat-2.1.0.tar.gz - 549.4kB of 549.4kB (100%)
> reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.txt
> reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.xml
> config: devel/gmp-6.1.0.cfg
> package: gmp-6.1.0-x86_64-linux-gnu-1
> download: https://gcc.gnu.org/pub/gcc/infrastructure/gmp-6.1.0.tar.bz2
> <https://gcc.gnu.org/pub/gcc/infrastructure/gmp-6.1.0.tar.bz2> ->
> sources/gmp-6.1.0.tar.bz2
> downloading: sources/gmp-6.1.0.tar.bz2 - 2.3MB of 2.3MB (100%)
> reporting: devel/gmp-6.1.0.cfg -> gmp-6.1.0-x86_64-linux-gnu-1.txt
> reporting: devel/gmp-6.1.0.cfg -> gmp-6.1.0-x86_64-linux-gnu-1.xml
> config: tools/rtems-gdb-10.cfg
> error: shell macro failed:
> /home/idadel/quick-start/src/rsb/source-builder/sb/rtems-build-dep -c gcc  -l :
> 2: error: no library (-l) provided
I think this looks like something with Windows and the shell.
Could you please run with --trace and then search the log file for this the
above line. The shell macro should be present that failed.
> Build FAILED
> Build Set: Time 0:00:12.713688
> Build FAILED
> Also for some reason when I run "sb-check" it tells me "command not found"
This looks like a Windows issue.
