Offline download of sources fails
Ida Delphine idadelm at gmail.com
Thu Mar 11 05:17:31 UTC 2021
My development host is Ubuntu 20.04 not Windows. Also I'm a bit confused on
how to run it with --trace to find the log file. Can you please help me
with some context?
Cheers,
Ida
On Thu, 11 Mar 2021, 6:07 am Chris Johns, <chrisj at rtems.org> wrote:
> On 11/3/21 3:34 pm, Ida Delphine wrote:
> > Hello again,
> > So I started over and downloaded all the required packages for my host
> (Ubuntu
> > 20.04) and still have offline download issues...
> > Please take a look at the error message:
> > RTEMS Source Builder - Set Builder, 6 (fe2d13b6daf3)
> > Build Set: 6/rtems-sparc
> > Build Set: 6/rtems-autotools.bset
> > Build Set: 6/rtems-autotools-internal.bset
> > config: tools/rtems-autoconf-2.69-1.cfg
> > config: tools/rtems-automake-1.12.6-1.cfg
> > Build Sizes: usage: 0.000B total: 19.014KB (sources: 0.000B, patches:
> 19.014KB,
> > installed 0.000B)
> > Build Set: Time 0:00:00.933172
> > Build Set: 6/rtems-autotools-base.bset
> 19.014KB,
> > installed 0.000B)
> > Build Set: Time 0:00:00.840448
> > Build Set: Time 0:00:01.777350
> > config: devel/expat-2.1.0-1.cfg
> > package: expat-2.1.0-x86_64-linux-gnu-1
> > Creating source directory: sources
> > download:
> https://github.com/libexpat/libexpat/releases/download/R_2_1_0/expat-2.1.0.tar.gz
> > -> sources/expat-2.1.0.tar.gz
> >  redirect:
> https://github-releases.githubusercontent.com/80314213/0186bc60-b675-11e7-83c0-13aced4
> https://github-releases.githubusercontent.com/80314213/0186bc60-b675-11e7-83c0-13aced4.
> .>.<see
> > log>
> > downloading: sources/expat-2.1.0.tar.gz - 549.4kB of 549.4kB (100%)
> > reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.txt
> > reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.xml
> > config: devel/gmp-6.1.0.cfg
> > package: gmp-6.1.0-x86_64-linux-gnu-1
> > download: https://gcc.gnu.org/pub/gcc/infrastructure/gmp-6.1.0.tar.bz2
> > <https://gcc.gnu.org/pub/gcc/infrastructure/gmp-6.1.0.tar.bz2> ->
> > sources/gmp-6.1.0.tar.bz2
> > downloading: sources/gmp-6.1.0.tar.bz2 - 2.3MB of 2.3MB (100%)
> > reporting: devel/gmp-6.1.0.cfg -> gmp-6.1.0-x86_64-linux-gnu-1.txt
> > reporting: devel/gmp-6.1.0.cfg -> gmp-6.1.0-x86_64-linux-gnu-1.xml
> > config: tools/rtems-gdb-10.cfg
> > error: shell macro failed:
> > /home/idadel/quick-start/src/rsb/source-builder/sb/rtems-build-dep -c
> gcc  -l :
> > 2: error: no library (-l) provided
> I think this looks like something with Windows and the shell.
> Could you please run with --trace and then search the log file for this the
> above line. The shell macro should be present that failed.
> > Build FAILED
> > Build Set: Time 0:00:12.713688
> > Build FAILED
> > Also for some reason when I run "sb-check" it tells me "command not
> found"
> This looks like a Windows issue.
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20210311/326f904e/attachment-0001.html>
