Error by building a BSP on Ubuntu 18.04
Fri Mar 12 00:19:49 UTC 2021
On Thu, Mar 11, 2021 at 2:41 PM Olga Syrbachova <syrba4eva28 at gmail.com>
wrote:
> It is RTEMS 5.1. I've checked the configure step. It seems to be fine. I
> get this:
> config.status: creating Makefile
> target architecture: sparc.
> available BSPs: erc32.
> 'make all' will build the following BSPs: erc32.
> other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
> And I still have the same error running make -j 2.
I wonder if you bootstrapped with the RTEMS autoconf/automake or the system
one.
type autoconf
and see which is picked up. Normally the RTEMS tools bin directory goes at
the
head of your PATH.
--joel
> On Thu, 11 Mar 2021 at 00:18, Gedare Bloom <gedare at rtems.org> wrote:
>> Hi Olga,
>> On Wed, Mar 10, 2021 at 1:35 PM Olga Syrbachova <syrba4eva28 at gmail.com>
>> wrote:
>> > Hi! I'm following this tutorial
>> https://docs.rtems.org/branches/master/user/installation/kernel.html.
>> > After successfully building a tool chain for the SPARC architecture in
>> step 5.1.1. I moved to the step 5.3.1. And then in step 5.3.4. I get an
>> error:
>> > olga at olga-H270M-DS3H:~/development/rtems/kernel/erc32$ make -j 2
>> > Making all in sparc-rtems5/c
>> > make[1]: Entering directory
>> '/home/olga/development/rtems/kernel/erc32/sparc-rtems5/c'
>> > Making all in .
>> > make[2]: Entering directory
>> > make[2]: Nothing to be done for 'all-am'.
>> > make[2]: Leaving directory
>> > Making all in erc32
>> '/home/olga/development/rtems/kernel/erc32/sparc-rtems5/c/erc32'
>> > make[2]: *** No rule to make target 'all'.  Stop.
>> > Makefile:362: recipe for target 'all-recursive' failed
>> > make[1]: *** [all-recursive] Error 1
>> > make[1]: Leaving directory
>> > Makefile:482: recipe for target 'all-recursive' failed
>> > make: *** [all-recursive] Error 1
>> We would need a bit more. Is this on rtems5? Often, this kind of
>> failure indicates that configure failed, check your configure step.
>> In RTEMS6 we will be getting rid of configure, but for now there is
>> support for both in the RTEMS6 'master' branch.
>> > Did I miss something or am I doing something wrong? Many thanks in
>> advance for your help!
>> > _______________________________________________
>> > users mailing list
>> > users at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210311/f14574bf/attachment.html>
