Error by building a BSP on Ubuntu 18.04
Olga Syrbachova
syrba4eva28 at gmail.com
Fri Mar 12 08:24:31 UTC 2021
Thank you very much for your reply! I've managed to install RTEMS 5 now :)
I'm not sure, but I suppose I confused somewhere the prefixes and where to
install and build all the things.
On Fri, 12 Mar 2021 at 01:20, Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Mar 11, 2021 at 2:41 PM Olga Syrbachova <syrba4eva28 at gmail.com>
> wrote:
>> It is RTEMS 5.1. I've checked the configure step. It seems to be fine. I
>> get this:
>> config.status: creating Makefile
>> target architecture: sparc.
>> available BSPs: erc32.
>> 'make all' will build the following BSPs: erc32.
>> other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
>> And I still have the same error running make -j 2.
> I wonder if you bootstrapped with the RTEMS autoconf/automake or the
> system one.
> type autoconf
> and see which is picked up. Normally the RTEMS tools bin directory goes at
> the
> head of your PATH.
> --joel
>> On Thu, 11 Mar 2021 at 00:18, Gedare Bloom <gedare at rtems.org> wrote:
>>> Hi Olga,
>>> On Wed, Mar 10, 2021 at 1:35 PM Olga Syrbachova <syrba4eva28 at gmail.com>
>>> wrote:
>>> > Hi! I'm following this tutorial
>>> https://docs.rtems.org/branches/master/user/installation/kernel.html.
>>> > After successfully building a tool chain for the SPARC architecture in
>>> step 5.1.1. I moved to the step 5.3.1. And then in step 5.3.4. I get an
>>> error:
>>> > olga at olga-H270M-DS3H:~/development/rtems/kernel/erc32$ make -j 2
>>> > Making all in sparc-rtems5/c
>>> > make[1]: Entering directory
>>> '/home/olga/development/rtems/kernel/erc32/sparc-rtems5/c'
>>> > Making all in .
>>> > make[2]: Entering directory
>>> > make[2]: Nothing to be done for 'all-am'.
>>> > make[2]: Leaving directory
>>> > Making all in erc32
>>> '/home/olga/development/rtems/kernel/erc32/sparc-rtems5/c/erc32'
>>> > make[2]: *** No rule to make target 'all'. Stop.
>>> > Makefile:362: recipe for target 'all-recursive' failed
>>> > make[1]: *** [all-recursive] Error 1
>>> > make[1]: Leaving directory
>>> > Makefile:482: recipe for target 'all-recursive' failed
>>> > make: *** [all-recursive] Error 1
>>> We would need a bit more. Is this on rtems5? Often, this kind of
>>> failure indicates that configure failed, check your configure step.
>>> In RTEMS6 we will be getting rid of configure, but for now there is
>>> support for both in the RTEMS6 'master' branch.
>>> > Did I miss something or am I doing something wrong? Many thanks in
>>> advance for your help!
>>> > _______________________________________________
>>> > users mailing list
>>> > users at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/users
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210312/47771379/attachment.html>
