instaling rtems on windows 10
Alireza Banejad alibanejad1376 at gmail.com
Thu Mar 18 14:25:05 UTC 2021
Hey Gedare
Thanks for the reply
I checked out rtems 7 and it seems to pass building gdb
It seems that the issue I mentioned is just for rtems 6
Also thanks for the ldflag tip. Yet I don't exactly know where to add this
flag. Is there some sort of file I need to edit and add the linker flag or
should I just pass it through the command line when building the rsb?
On Wed, Mar 17, 2021, 21:28 Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Mar 17, 2021 at 5:07 AM Alireza Banejad
> <alibanejad1376 at gmail.com> wrote:
> > hello every one
> > I'm trying to  install rtems 6 arm toolchain on windows 10 but when the
> source builder tries to build the rtems-gdb-10 it results in an error
> > reading the report gives me the following:
> C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe:
> ../gnulib/import/libgnu.a(getrandom.o): in function `getrandom':
> C:\opt\rtems\rsb\rtems\build\argfxwm1\build\gnulib\import/../../../sourceware-mirror-binutils-gdb-fc9b4c8/gnulib/import/getrandom.c:129:
> undefined reference to `BCryptGenRandom'
> This looks relevant:
> http://sourceware-org.1504.n7.nabble.com/Unable-to-build-GDB-on-Windows-td649748.html
> It seems that the configure probe for getrandom picks up libbcrypt
> exists on your Windows, but then it does not get linked properly. This
> seems to be a gdb build system problem. Possibly a newer gdb has fixed
> it? You might be able to figure out how to add -lbcrypt to your linker
> flags (export LDFLAGS=-lbcrypt   might just work) locally while
> compiling GDB.
> > collect2.exe: error: ld returned 1 exit status
> > make[2]: *** [Makefile:1866: gdb.exe] Error 1
> > make[2]: Leaving directory
> '/c/opt/rtems/rsb/rtems/build/argfxwm1/build/gdb'
> > make[1]: *** [Makefile:9744: all-gdb] Error 2
> > make[1]: Leaving directory '/c/opt/rtems/rsb/rtems/build/argfxwm1/build'
> > make: *** [Makefile:866: all] Error 2
> > shell cmd failed: sh -ex  /c/opt/rtems/rsb/rtems/build/argfxwm1/do-build
> > error: building argfxwm1
> > Any thoughts?
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20210318/6ec361c1/attachment.html>
