RTEMS SMP does not work on Xilinx ZynqMP
amir taghavi
a.taghavi74 at gmail.com
Mon May 3 07:08:09 UTC 2021
Hello all,
I ran RTEMS v5 on Xilinx ZCU102 leveraging ZynqMP BSP, without enabling SMP
everything worked just fine but when I enabled SMP neither of the cores
started except core 0.
I’ve looked for the problem in the RTEMS source code and I reached
bsp_start_hook_0() function.
I think the problem is that the arm_a9mpcore_start_hook_0() function which
is responsible for changing the state of cores to up_state is not called in
bsp_start_hook_0() function in ZynqMP BSP despite of Zynq BSP.
Is this the explanation to this problem or something else is wrong? Any
help would be appreciated.
Best regards
Amirhossein
URL: <http://lists.rtems.org/pipermail/users/attachments/20210503/3ce1e6fd/attachment.html>
