About runnning RTEMS on qemu
Richi Dubey
richidubey at gmail.com
Thu May 20 08:11:16 UTC 2021
Thank you for your prompt replies.
I am going to try the leon3, xilinx_zynq_a9_qemu, griscv, and riscv32 bsp.
I'll post here if any of the bsps help me find the bug.
Thanks!
On Thu, May 20, 2021 at 1:58 AM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, May 19, 2021 at 3:45 AM Richi Dubey <richidubey at gmail.com> wrote:
>> Hi,
>> I do not have access to a real board, and I wanted to run a test on
>> different architectures (or bsps) over qemu to see if there is anything
>> amiss with the test.
>> So, I ran the SMP test that I developed on realview_pbx_a9_qemu (arm),
>> but I want to test on a few more boards/debuggers. Can you please suggest
>> to me bsps that you work right out of the box on qemu for a SMP
>> system(without needing much configuration):
>> Have you guys tried one of these recently?
>> a53_lp64_qemu aarch64
> Eventually but right now aarch64 does not have SMP support.
>> lm3s6965_qemu arm
> I don't think this particular ARM variant has SMP support in hardware.
>> xilinx_zynq_a9_qemu arm
> This should work.
> A sufficiently high pc BSP variant should also work on qemu.
>> qemuprep powerpc
>> qemuprep-altivec powerpc
>> qemuppc powerpc
> The real hardware didn't support SMP but worse, these qemu models are
> marked for removal and I don't know that I ever knew how to use them. I
> vaguely recall having to have a boot ROM image but that memory may
> be flawed.
>> Can I use sparc leon3 and use sis/gdb as well for a SMP test?
> leon3 should do SMP on sis (but not the one in gdb which is now disabled)
> as well as when using qemu.
> Jiri's standalone sis is nice for leon and riscv SMP.
> --joel
>> Thanks!
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210520/bee5dc5a/attachment-0001.html>
