About runnning RTEMS on qemu
Richi Dubey
richidubey at gmail.com
Thu May 20 10:04:46 UTC 2021
Thanks!
On Thu, May 20, 2021 at 3:06 PM Hesham Almatary <
hesham.almatary at cl.cam.ac.uk> wrote:
> On Thu, 20 May 2021 at 10:12, Richi Dubey <richidubey at gmail.com> wrote:
> > Thank you for your prompt replies.
> > I am going to try the leon3, xilinx_zynq_a9_qemu, griscv, and riscv32
> bsp. I'll post here if any of the bsps help me find the bug.
> I believe RISCV64 is also tested on QEMU (by rtems-tester), with SMP tests.
> > Thanks!
> > On Thu, May 20, 2021 at 1:58 AM Joel Sherrill <joel at rtems.org> wrote:
> >> On Wed, May 19, 2021 at 3:45 AM Richi Dubey <richidubey at gmail.com>
> wrote:
> >>> Hi,
> >>> I do not have access to a real board, and I wanted to run a test on
> different architectures (or bsps) over qemu to see if there is anything
> amiss with the test.
> >>> So, I ran the SMP test that I developed on realview_pbx_a9_qemu (arm),
> but I want to test on a few more boards/debuggers. Can you please suggest
> to me bsps that you work right out of the box on qemu for a SMP
> system(without needing much configuration):
> >>> Have you guys tried one of these recently?
> >>> a53_lp64_qemu aarch64
> >> Eventually but right now aarch64 does not have SMP support.
> >>> lm3s6965_qemu arm
> >> I don't think this particular ARM variant has SMP support in hardware.
> >>> xilinx_zynq_a9_qemu arm
> >> This should work.
> >> A sufficiently high pc BSP variant should also work on qemu.
> >>> qemuprep powerpc
> >>> qemuprep-altivec powerpc
> >>> qemuppc powerpc
> >> The real hardware didn't support SMP but worse, these qemu models are
> >> marked for removal and I don't know that I ever knew how to use them. I
> >> vaguely recall having to have a boot ROM image but that memory may
> >> be flawed.
> >>> Can I use sparc leon3 and use sis/gdb as well for a SMP test?
> >> leon3 should do SMP on sis (but not the one in gdb which is now
> disabled)
> >> as well as when using qemu.
> >> Jiri's standalone sis is nice for leon and riscv SMP.
> >> --joel
> >>> Thanks!
> >>> _______________________________________________
> >>> users mailing list
> >>> users at rtems.org
> >>> http://lists.rtems.org/mailman/listinfo/users
> > users mailing list
> > users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210520/6de670dd/attachment.html>
