Manually building a BSP from branch 5 of git
Vijay Kumar Banerjee vijay at rtems.org
Wed May 26 01:18:28 UTC 2021
Hi Andrew,
I found the 5.1 docs version from rtems ftp. This looks like the right one:
https://ftp.rtems.org/pub/rtems/releases/5/5.1/docs/html/user/start/bsp-build.html#manual-bsp-build
Best regards,
Vijay
On Tue, May 25, 2021 at 5:27 PM Johnson, Andrew N. <anj at anl.gov> wrote:
> Hi,
> I’m trying to develop fixes for issues that I’m seeing in some of the powerpc/motorola_powerpc BSPs, and I’m working on the 5 branch (it doesn’t look like those have been fixed on the master branch yet either). I have built the tools and those BSPs before using RSB but now I need to build my modified sources, and I think the docs say that I have to do that manually. That’s fine, but unfortunately the instructions at 2.5.2. Manual BSP Build seem to be for the master branch and don’t work for me because there was no waf script present on branch 5. Are there any alternative instructions that I can follow to do a manual build of this branch?
> Thanks,
> - Andrew
> Complexity comes for free, simplicity you have to work for.
> users mailing list
> users at rtems.org
