Manually building a BSP from branch 5 of git
Johnson, Andrew N. anj at anl.gov
Tue May 25 23:26:56 UTC 2021
Hi,
I’m trying to develop fixes for issues that I’m seeing in some of the powerpc/motorola_powerpc BSPs, and I’m working on the 5 branch (it doesn’t look like those have been fixed on the master branch yet either). I have built the tools and those BSPs before using RSB but now I need to build my modified sources, and I think the docs say that I have to do that manually. That’s fine, but unfortunately the instructions at 2.5.2. Manual BSP Build<https://docs.rtems.org/branches/master/user/start/bsp-build.html#manual-bsp-build> seem to be for the master branch and don’t work for me because there was no waf script present on branch 5. Are there any alternative instructions that I can follow to do a manual build of this branch?
Thanks,
- Andrew
Complexity comes for free, simplicity you have to work for.
URL: <http://lists.rtems.org/pipermail/users/attachments/20210525/542dab92/attachment.html>
