Manually building a BSP from branch 5 of git
Johnson, Andrew N.
anj at anl.gov
Wed May 26 06:10:58 UTC 2021
Hi Vijay,
On May 25, 2021, at 8:18 PM, Vijay Kumar Banerjee <vijay at rtems.org<mailto:vijay at rtems.org>> wrote:
I found the 5.1 docs version from rtems ftp. This looks like the right one:
https://ftp.rtems.org/pub/rtems/releases/5/5.1/docs/html/user/start/bsp-build.html#manual-bsp-build
Excellent, thanks – I would have expected that version of the User Manual to be linked from the Releases table of https://devel.rtems.org/ on the row for branch 5.
How do I set BSP options like this flag to RSB?
--with-rtems-bspopts="BSP_CONSOLE_BAUD=9600”
Does the --enable-networking flag to configure do the equivalent of this RSB flag?
--with-rtems-legacy-network
If that’s the case would I have to build the libbsd network stack as a separate build?
Thanks,
- Andrew
On Tue, May 25, 2021 at 5:27 PM Johnson, Andrew N. <anj at anl.gov<mailto:anj at anl.gov>> wrote:
Hi,
I’m trying to develop fixes for issues that I’m seeing in some of the powerpc/motorola_powerpc BSPs, and I’m working on the 5 branch (it doesn’t look like those have been fixed on the master branch yet either). I have built the tools and those BSPs before using RSB but now I need to build my modified sources, and I think the docs say that I have to do that manually. That’s fine, but unfortunately the instructions at 2.5.2. Manual BSP Build seem to be for the master branch and don’t work for me because there was no waf script present on branch 5. Are there any alternative instructions that I can follow to do a manual build of this branch?
Thanks,
- Andrew
Complexity comes for free, simplicity you have to work for.
users mailing list
users at rtems.org<mailto:users at rtems.org>
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20210526/fe62cdf0/attachment-0001.html>
