get_heap_info memsets stats element
Matthew J Fletcher
amimjf at gmail.com
Fri Apr 15 11:01:42 UTC 2022
Hi Joel
> Would be good to have a comment here explaining that. Patch welcome. :_
I think i probably owe you a patch, given i've been using RTEMS (on-off)
now for 20 years, at least back to
https://lists.rtems.org/pipermail/users/2001-November/037648.html
m68k targets, RedHat 5 build machines with 64mb ram, those were the days !
regards, Matthew.
On Wed, 13 Apr 2022 at 15:58, Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Apr 13, 2022 at 8:32 AM Matthew J Fletcher <amimjf at gmail.com>
> wrote:
>> Hi,
>> _Heap_Get_information provides the information but its then memset after
>> retrieval, is this a bug or design ?
>> _Heap_Get_information(heap, info);
>> memset(&info->Stats, 0, sizeof(info->Stats));
> In this case, this call is in support of resource snapshot. This is used
> in tests
> to ensure the number of objects/allocations is the same before and after a
> test case is executed. It verifies no leaks.
> The stats section has the number of calls, maximum memory allocated, etc.
> and
> would legitimately change. By zero'ing it out, it makes it possible to
> compare
> the before and after versions.
> --joel
>> regards
>> Matthew J Fletcher
>> users mailing list
>> users at rtems.org
regards
Matthew J Fletcher
