Want to add RISC-V-based PolarFire SoC support to RTEMS
Thu Aug 25 12:42:00 UTC 2022
On Thu, Aug 25, 2022, 12:08 AM <Padmarao.Begari at microchip.com> wrote:
> Hi Hesham,
> The generic RISC-V BSP is working on the PolarFire SoC without SMP but
> doesn't work with SMP because it expects first HARTID  should be '0', t
> he PolarFire SoC SMP starts with HARTID '1'(U54) because the HARTID
> '0'(E51) reserved for first state booatloader. When the RTEMS is executing
> on the PolarFire SoC it reads hartid number with "HARTID-1" so that the SMP
> can start from hartid '0'.
> i.e reason I have added seperate BSP for the PolarFire SoC.
> Yes, there is a lot of code duplication and will try to re-use the
> existing code for the PolarFire SoC with modification.
You are on a path to create a BSP variant. Share entire files via build
system. Set conditional variables for small things. For larger things just
pick different files.
> Will remove platform-dependent #ifdefs in startup code, is it Ok to
> add CPU dependent #ifdefs?
Where? Usually if they are small sections of code, it's ok in a BSP
Just balance amount shared versus just swapping the file, refactoring a
helper method which can be swapped at the file level, etc
> Regards
> Padmarao
> On Wed, 2022-08-24 at 11:00 +0100, Hesham Almatary wrote:
> > Hello Padmarao,
> > It would be great to have support for running RTEMS on PolarFire.
> > I had a quick look at the code. There is a lot of code duplications
> > already. The generic RISC-V BSP already has SMP, CLINT, PLIC, and
> > 16550 support. Why can't this code be shared (i.e., if you use the
> > riscv/riscv BSP and just provide your FDT)?
> > I'd also try to avoid introducing platform-dependent #ifdefs in
> > shared
> > code (e.g., start.S).
> > Cheers,
> > Hesham
> > On Wed, 24 Aug 2022 at 08:14, <Padmarao.Begari at microchip.com> wrote:
> > > Hi,
> > > I want to add a new BSP for RISC-V-based Microchip PolarFire
> > > SoC(MPFS)
> > > to RTEMS.
> > > The PolarFire SoC is the 4x 64-bit RISC-V U54 cores and a 64-bit
> > > RISC-
> > > V
> > > E51 monitor core SoC from Microchip.
> > > The new BSP is added for the U54 cores not for E51 because the E51
> > > moniter core is resreved for first stage bootloader (Hart Software
> > > Services).
> > > This BSP supports below components:
> > >     4 CPU Cores (U54)
> > >     Interrupt controller (PLIC)
> > >     Timer (CLINT)
> > >     UART (mmuart, 16550-compatible)
> > > We have already done some work on this and tested but not with
> > > latest
> > > RTEMS source(8th March, 2022 commit) and want to send patches with
> > > latest source.
> > > https://github.com/polarfire-soc/rtems/tree/mpfs-rtems
> > > Regards
> > > Padmarao
> > > _______________________________________________
> > > users mailing list
> > > users at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20220825/acdca6e2/attachment.htm>
