Want to add RISC-V-based PolarFire SoC support to RTEMS
Padmarao.Begari at microchip.com Padmarao.Begari at microchip.com
Fri Aug 26 11:37:26 UTC 2022
Hi Hesham,
The boot HARTID configurable is Ok but I am thinking about SMP.
The PolarFire SoC has 4 U54's with hartid 1,2,3,4 but the SMP
starts with cpu number '0' to MAX cpu number then the PolarFire
SoC U54's hartid number should become 0,1,2,3 to run the SMP.
Regards
Padmarao
On Thu, 2022-08-25 at 10:05 +0100, Hesham Almatary wrote:
> Hello Padmarao,
> I wonder if we can make the boot HARTID configuragle in RTEMS for
> RISC-V. Something like introducing a new option (e.g.,
> optboothartid.yml) in the generic RISC-V BSP.
> On Thu, 25 Aug 2022 at 06:08, <Padmarao.Begari at microchip.com> wrote:
> > Hi Hesham,
> > The generic RISC-V BSP is working on the PolarFire SoC without SMP
> > but
> > doesn't work with SMP because it expects first HARTID  should be
> > '0', t
> > he PolarFire SoC SMP starts with HARTID '1'(U54) because the HARTID
> > '0'(E51) reserved for first state booatloader. When the RTEMS is
> > executing on the PolarFire SoC it reads hartid number with "HARTID-
> > 1" so that the SMP can start from hartid '0'.
> > i.e reason I have added seperate BSP for the PolarFire SoC.
> > Yes, there is a lot of code duplication and will try to re-use the
> > existing code for the PolarFire SoC with modification.
> > Will remove platform-dependent #ifdefs in startup code, is it Ok to
> > add CPU dependent #ifdefs?
> > Regards
> > Padmarao
> > On Wed, 2022-08-24 at 11:00 +0100, Hesham Almatary wrote:
> > > Hello Padmarao,
> > > It would be great to have support for running RTEMS on PolarFire.
> > > I had a quick look at the code. There is a lot of code
> > > duplications
> > > already. The generic RISC-V BSP already has SMP, CLINT, PLIC, and
> > > 16550 support. Why can't this code be shared (i.e., if you use
> > > the
> > > riscv/riscv BSP and just provide your FDT)?
> > > I'd also try to avoid introducing platform-dependent #ifdefs in
> > > shared
> > > code (e.g., start.S).
> > > Cheers,
> > > Hesham
> > > On Wed, 24 Aug 2022 at 08:14, <Padmarao.Begari at microchip.com>
> > > wrote:
> > > > Hi,
> > > > I want to add a new BSP for RISC-V-based Microchip PolarFire
> > > > SoC(MPFS)
> > > > to RTEMS.
> > > > The PolarFire SoC is the 4x 64-bit RISC-V U54 cores and a 64-
> > > > bit
> > > > RISC-
> > > > V
> > > > E51 monitor core SoC from Microchip.
> > > > The new BSP is added for the U54 cores not for E51 because the
> > > > E51
> > > > moniter core is resreved for first stage bootloader (Hart
> > > > Software
> > > > Services).
> > > > This BSP supports below components:
> > > >     4 CPU Cores (U54)
> > > >     Interrupt controller (PLIC)
> > > >     Timer (CLINT)
> > > >     UART (mmuart, 16550-compatible)
> > > > We have already done some work on this and tested but not with
> > > > latest
> > > > RTEMS source(8th March, 2022 commit) and want to send patches
> > > > with
> > > > latest source.
> > > > https://github.com/polarfire-soc/rtems/tree/mpfs-rtems
> > > > Regards
> > > > Padmarao
> > > > _______________________________________________
> > > > users mailing list
> > > > users at rtems.org
> > > > http://lists.rtems.org/mailman/listinfo/users
> > users mailing list
> > users at rtems.org
