Split BSP in RTEMS 4.11 - autotools newbie question
Joel Sherrill
joel at rtems.org
Mon Mar 14 13:10:22 UTC 2022
On Mon, Mar 14, 2022 at 7:37 AM Dariusz.sabala <dsa93 at pm.me> wrote:
> Hello
> I am developing SAMRH71 BSP in RTEMS 4.11, I started editing atsam BSP and
> accomplished some success, but the decision was made to support both BSP
> (atsam and samrh71) in separate folders. I reverted my changes, copied and
> renamed atsam folder to samrh71 and tried to build this renamed BSP, but
> unfortunately nothing is being built - make just enters the folder and
> leaves it with no artifact build
> make[1]: Entering directory
> '/home/dsa/projects/p1/repo/rtems/samrh71/arm-rtems4.11/c'
> Making all in .
> make[2]: Entering directory
> make[2]: Nothing to be done for 'all-am'.
> Can you give me advice on what and where to change in the buildsystem to
> make it build? Honestly I am cmake kid :) and knowing that autotools is no
> longer supported in the newest RTEMS does not encourage learning this
> powerful but complex tool.
Assuming there aren't any mistakes lurking. :)
>From the top directory:
bootstrap -c
bootstrap -p
bootstrap
When you add, move, and delete directories, it is possible that the
generated fragments which include lists of BSPs could get out of sync.
Overall, I'd recommend you move to 6.
--joel
> Best regards
> dsa
> users mailing list
> users at rtems.org
