[PATCH] score: Simplify _Watchdog_Tick()
Joel Sherrill
joel at rtems.org
Wed Feb 17 13:51:09 UTC 2016
This seems OK.
I think it is in sync with the simulator clock tick idle thread. But double
check.
On Feb 17, 2016 5:54 AM, "Sebastian Huber" <
> Move thread dispatch disable check to legacy rtems_clock_tick(). Assert
> that thread dispatching is disabled in _Watchdog_Tick(). This is
> usually the case, since this function is called in interrupt context by
> the clock tick service routine.
> cpukit/rtems/src/clocktick.c | 5 +++++
> cpukit/score/src/watchdogtick.c | 8 ++++----
> 2 files changed, 9 insertions(+), 4 deletions(-)
> diff --git a/cpukit/rtems/src/clocktick.c b/cpukit/rtems/src/clocktick.c
> index a6bf26d..df8012e 100644
> --- a/cpukit/rtems/src/clocktick.c
> +++ b/cpukit/rtems/src/clocktick.c
> @@ -20,6 +20,7 @@
> #include <rtems/rtems/clock.h>
> #include <rtems/score/timecounter.h>
> +#include <rtems/score/threadimpl.h>
> rtems_status_code rtems_clock_tick( void )
> @@ -32,5 +33,9 @@ rtems_status_code rtems_clock_tick( void )
> &lock_context
> + if ( _Thread_Dispatch_is_enabled() ) {
> + _Thread_Dispatch();
> return RTEMS_SUCCESSFUL;
> diff --git a/cpukit/score/src/watchdogtick.c
> b/cpukit/score/src/watchdogtick.c
> index b9bc3f7..cb68ea2 100644
> --- a/cpukit/score/src/watchdogtick.c
> +++ b/cpukit/score/src/watchdogtick.c
> @@ -12,8 +12,9 @@
> * http://www.rtems.org/license/LICENSE.
> +#include <rtems/score/assert.h>
> #include <rtems/score/schedulerimpl.h>
> -#include <rtems/score/threadimpl.h>
> +#include <rtems/score/threaddispatch.h>
> #include <rtems/score/todimpl.h>
> #include <rtems/score/watchdogimpl.h>
> @@ -23,12 +24,11 @@
> void _Watchdog_Tick( void )
> + _Assert( !_Thread_Dispatch_is_enabled() );
> _TOD_Tickle_ticks();
> _Watchdog_Tickle_ticks();
> _Scheduler_Tick();
> - if ( _Thread_Dispatch_is_enabled() )
> - _Thread_Dispatch();
> 1.8.4.5
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160217/5af30c63/attachment.html>
