sparc-rtems-gdb doesn't recognize target "sim"
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Wed Nov 13 07:36:08 UTC 2019
On Wed, Nov 13, 2019 at 12:39 AM Shubham Bhagat <shubhambhagat111 at yahoo.com>
wrote:
> Hello everyone,
> I've been trying to run the hello world example in source tree
> <https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start#Running> to get
> started with sparc/erc32 but after building all that is required ( followed POSIX
> Compliance (Getting started challenge for RTEMS beginners)
> <https://rmeena840.github.io/Third-Post/>). I
> followed all the commands. But, when gdb starts and I set "tar sim" it
> says:
> Undefined target command: "sim". Try "help target".
> I also tried running hello.exe from the testsuites sample using
> sparc-rtems5-run but it doesn't recognize the command.
> NOTE: The make and make install steps didn't finish with a "SUCCESS" or
> anything. They exited without showing any error.
> Am I missing out anything here?
> I guess this thread will be helpful for you:
https://lists.rtems.org/pipermail/devel/2019-September/055671.html
> POSIX Compliance (Getting started challenge for RTEMS beginners)
> Ravindra Kumar Meena
> POSIX stands for Portable Operating System Interface for uni-X. POSIX
> Compliance allows us to port the source co...
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191113/0457b454/attachment-0001.html>
