GSoC 2020: Location for FreeBSD files in RTEMS
Niteesh G. S.
niteesh.gs at gmail.com
Thu Jul 9 14:02:25 UTC 2020
Hello,
The current directory structure I have been using in my GSoC project
for the FreeBSD drivers is giving me troubles while installing/including
the headers.
The current structure of the drivers is as follows
cpukit/libfreebsd/freebsd --> After this we follow the FreeBSD file
structure
Eg: ti_pinmux.h is placed under sys/arm/ti/ti_pinmux.h in FreeBSD
In RTEMS this is placed under
cpukit/libfreebsd/freebsd/sys/arm/ti/ti_pinmux.h
And the files implemented to make porting easier are placed under
cpukit/libfreebsd/rtems
You can find these files here
https://github.com/gs-niteesh/rtems/tree/rtemsbsd/cpukit/libfreebsd/rtems
I have already started a discussion and written a blog about these files
please check out
https://lists.rtems.org/pipermail/devel/2020-July/060541.html
With the current structure, we aren't able to include the header files in
BSP and test suite directory.
The spec file for libfreebsd can be found here
https://github.com/gs-niteesh/rtems/blob/pinmux-rtems-6/spec/build/cpukit/objfreebsd.yml
After a discussion regarding this with Christian, he suggested to break out
of the FreeBSD structure and place the header files under cpukit/include
and install them with FreeBSD like structure.
I tried this and was able to include the headers in the BSP and testsuite
directory.
On using this approach we have the following structure.
FreeBSD header files are under
cpukit/include
FreeBSD source files under
We will also be using the same approach for the files that have implemented
to make porting easier.
All the headers will be placed under
cpukit/include
The source files under
cpukit/libfreebsd/rtems ( Currently we are having only one source file).
I kindly request everyone to quickly provide their feedback on this
structure
since this is hampering my progress. If you don't like this structure please
suggest something better.
Thank you,
Niteesh.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200709/146be330/attachment-0001.html>
