[PATCH v2 0/4] Add ZynqMP Cortex-R5 BSP
Philip Kirkpatrick
p.kirkpatrick at reflexaerospace.com
Tue Oct 24 14:10:28 UTC 2023
Kinsey,
I looked this over and built and tested it on actual hardware. I made the
minor changes below, but afterwards it worked as expected. The change to
`bspmercuryxu5.yml` was required to allow my application to find
`peripheral_maps/xilinx_zynqmp.h`. The other changes were not required,
but cleaned up some warnings.
bsps/arm/xilinx-zynqmp-rpu/include/bsp.h | 2 +-
bsps/arm/xilinx-zynqmp-rpu/start/bspstartmpu.c | 6 +++---
spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercuryxu5.yml | 4 +++-
3 files changed, 7 insertions(+), 5 deletions(-)
diff --git a/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
b/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
index db3997677f..e386bd4b26 100644
--- a/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
+++ b/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
@@ -81,7 +81,7 @@ extern "C" {
* Provide in the application to override the defaults in the BSP.
-BSP_START_TEXT_SECTION void zynqmp_setup_mmu_and_cache(void);
+BSP_START_TEXT_SECTION void zynqmp_setup_mpu_and_cache(void);
void zynqmp_debug_console_flush(void);
diff --git a/bsps/arm/xilinx-zynqmp-rpu/start/bspstartmpu.c
b/bsps/arm/xilinx-zynqmp-rpu/start/bspstartmpu.c
index 7c927058f7..8c591890bf 100644
--- a/bsps/arm/xilinx-zynqmp-rpu/start/bspstartmpu.c
+++ b/bsps/arm/xilinx-zynqmp-rpu/start/bspstartmpu.c
@@ -123,19 +123,19 @@ static BSP_START_TEXT_SECTION void
zynqmp_configure_mpu_sections(void)
Xil_SetMPURegion(addr, size, attrib);
// Add RO region for RO section
- addr = bsp_section_rodata_begin;
+ addr = (u32)bsp_section_rodata_begin;
size = bsp_section_rodata_end - bsp_section_rodata_begin;
attrib = NORM_NSHARED_WB_WA | PRIV_RO_USER_RO;
// Add no cache region for no cache section
- addr = bsp_section_nocache_begin;
+ addr = (u32)bsp_section_nocache_begin;
size = bsp_section_nocache_end - bsp_section_nocache_begin;
attrib = NORM_SHARED_NCACHE | PRIV_RW_USER_RW;
// Add no cache region for no cache no load section
- addr = bsp_section_nocachenoload_begin;
+ addr = (u32)bsp_section_nocachenoload_begin;
size = bsp_section_nocachenoload_end - bsp_section_nocachenoload_begin;
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercuryxu5.yml
b/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercuryxu5.yml
index 342cfdea57..595c1ad507 100644
--- a/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercuryxu5.yml
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercuryxu5.yml
@@ -16,10 +16,12 @@ install:
source:
- bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
- bsps/include/dev/clock/xttcps_hw.h
- - bsps/include/peripheral_maps/xilinx_zynqmp.h
- destination: ${BSP_INCLUDEDIR}/bsp
source:
- bsps/arm/xilinx-zynqmp-rpu/include/bsp/irq.h
+- destination: ${BSP_INCLUDEDIR}/peripheral_maps
+ source:
+ - bsps/include/peripheral_maps/xilinx_zynqmp.h
links:
- role: build-dependency
uid: ../grp
On Fri, Oct 20, 2023 at 7:03 PM Kinsey Moore <kinsey.moore at oarcorp.com>
wrote:
> Philip,
> When you get a chance, could you verify that this refactoring meets your
> expectations as far as functionality? I'm especially interested in whether
> the timer interrupts behave as you expect them to on hardware. I don't mind
> getting the Xilinx support code updates committed, but I'd like some
> feedback on the BSP itself.
> Kinsey
> On Thu, Oct 12, 2023 at 12:02 PM Kinsey Moore <kinsey.moore at oarcorp.com>
> wrote:
>> Changes from v1 (originally submitted by Philip Kirkpatrick):
>> Refactoring:
>> * import Xilinx code before modification
>> * better use the existing Xilinx support code
>> Other:
>> * An additional patch to add cache support (also from Philip) has been
>> integrated and refactored
>> This has been tested on Xilinx's QEMU with Xilinx's device tree
>> definitions using the following command line options to QEMU:
>> -no-reboot -nographic -M arm-generic-fdt -serial null -serial mon:stdio \
>> -device loader,file=<RTEMS exe path>,cpu-num=4 \
>> -device loader,addr=0xff5e023c,data=0x80088fde,data-len=4 \
>> -device loader,addr=0xff9a0000,data=0x80000218,data-len=4 \
>> -hw-dtb <XLNX DTB dir>/LATEST/SINGLE_ARCH/board-zynqmp-zcu102.dtb \
>> -m 4096 -display none
>> hello.exe and ts-validation-cache.exe operated as expected. Ticker
>> produced output, but the timing and content was incorrect on QEMU.
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20231024/cd690667/attachment-0001.htm>
