Networking with MVME2307 (actually MVM2400)
VALETTE Eric valette at crf.canon.fr
Thu Aug 9 15:07:14 UTC 2001
tsmith at megaroms.co.uk wrote:
> I'm trying to compile the netdemo program from netdemos-4.5.0 using the MVME2307 bsp. I get a warning that RTEMS_BSP_NETWORK_DRIVER_NAME hasn't been defined. It's not defined in the bsp so should I manually define it? What should I define it as? Same for RTEMS_BSP_NETWORK_DRIVER_ATTACH.
> I'm guessing this is relatively important as running the program on the board after these warnings are given results in a crash:
> RTEMS RELEASE rtems-4.5.0(PowerPC/PowerPC 604/mvme2307) PANIC OpenPic Not found
> exception handler called for exception 12
>          Next PC or Address of fault = 475c
>          Saved MSR = 3032
>          R0 = 4758
>          R1 = 5cf60
>          R2 = 0
>          LR = 4758
>          MSR = 50000
> unrecoverable exception!!! Push reset button
> Help much appreciated
The bug is not related to network but to card memory mapping : the
OpenPic (Raven Host bridge) is not correctly configured. Did you by
change read the
c/src/lib/libbsp/powerpc/motorola_powerpc/
		README
		BOOTING
		README.MVME2300
    __
   /  `                          Eric Valette - Canon CRF
  /--   __  o _.                 Canon Development Europe Team Leader
(___, / (_(_(__                 Rue de la touche lambert
                                 35517 Cesson-Sevigne  Cedex
                                 FRANCE
Tel: +33 (0)2 99 87 68 91       Fax: +33 (0)2 99 84 11 30
E-mail: valette at crf.canon.fr    http://www.crf.canon.fr
