Networking with MVME2307 (actually MVM2400)
tsmith at agsplanning.f9.co.uk tsmith at agsplanning.f9.co.uk
Thu Aug 9 15:56:27 UTC 2001
I've already changed the memory mapping as in README.MVME2300. Other test programs run fine (so far) except these networking things. Further testing reveals if I comment out the doSocket() bit in netdemo the program runs fine (but doesn't do anything :)) A call to a blank doSocket() causes the program to crash with an exception when the call to doSocket() is made.
I'd also still like to know how to properly set up
RTEMS_BSP_NETWORK_DRIVER_NAME.
>tsmith at megaroms.co.uk wrote:
>> I'm trying to compile the netdemo program from netdemos-4.5.0 using the MVME2307 bsp. I get a warning that RTEMS_BSP_NETWORK_DRIVER_NAME hasn't been defined. It's not defined in the bsp so should I manually define it? What should I define it as? Same for RTEMS_BSP_NETWORK_DRIVER_ATTACH.
>> I'm guessing this is relatively important as running the program on the board after these warnings are given results in a crash:
>> RTEMS RELEASE rtems-4.5.0(PowerPC/PowerPC 604/mvme2307) PANIC OpenPic Not found
>> exception handler called for exception 12
>>          Next PC or Address of fault = 475c
>>          Saved MSR = 3032
>>          R0 = 4758
>>          R1 = 5cf60
>>          R2 = 0
>>          LR = 4758
>>          MSR = 50000
>> unrecoverable exception!!! Push reset button
>> Help much appreciated
>The bug is not related to network but to card memory mapping : the
>OpenPic (Raven Host bridge) is not correctly configured. Did you by
>change read the
>c/src/lib/libbsp/powerpc/motorola_powerpc/
>		README
>		BOOTING
>		README.MVME2300
>    __
>   /  `                          Eric Valette - Canon CRF
>  /--   __  o _.                 Canon Development Europe Team Leader
>(___, / (_(_(__                 Rue de la touche lambert
>                                 35517 Cesson-Sevigne  Cedex
>                                 FRANCE
>Tel: +33 (0)2 99 87 68 91       Fax: +33 (0)2 99 84 11 30
>E-mail: valette at crf.canon.fr    http://www.crf.canon.fr
