RTEMS tools invalid version file
Tue Oct 30 00:20:06 UTC 2018
On 29/10/2018 23:03, Heinz P. Junkes wrote:
> Try to run waf in rtems tools:
> [h1 at earth rtems-tools (master)]$ ./waf configure
> --prefix=/home/h1/RTEMS/rtems/5.0 build install
> Setting top to                           : /home/h1/RTEMS_DEV/rtems-tools
> Setting out to                           : /home/h1/RTEMS_DEV/rtems-tools/build
> invalid version file: error: Invalid revision config value:
> /home/h1/RTEMS_DEV/rtems-tools/config/rtems-version.ini: 0.not_released:
> descriptor 'isdigit' requires a 'str' object but received a 'unicode'
> (complete log in /home/h1/RTEMS_DEV/rtems-tools/build/config.log)
> [h1 at earth rtems-tools (master)]$ more
> # project  configured on Mon Oct 29 12:58:24 2018 by
> # waf 1.9.9 (abi 99, python 2070fc1 on linux2)
> # using ./waf configure --prefix=/home/h1/RTEMS/rtems/5.0 build install
> Setting top to
> Setting out to
> from /home/h1/RTEMS_DEV/rtems-tools: Could not load the Waf tool 'doxygen' from
> ['/home/h1/RTEMS_DEV/rtems-tools/.waf-1.9.9-75529a659e4f06cb4254801e52405e0a', '/
> home/h1/RTEMS_DEV/rtems-tools',
> '/usr/local/lib/python2.7/dist-packages/setuptools-18.0.1-py2.7.egg',
> '/usr/local/lib/python2.7/dist-packages/pyepics-3.2.4-py2.7
> .egg', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-x86_64-linux-gnu',
> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
> '/usr/lib/python2.7/lib-dynlo
> ad', '/home/h1/.local/lib/python2.7/site-packages',
> '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages',
> es/gtk-2.0', '/usr/lib/python2.7/dist-packages/wx-3.0-gtk3']
> No module named doxygen
> from /home/h1/RTEMS_DEV/rtems-tools: invalid version file: error: Invalid
> revision config value: /home/h1/RTEMS_DEV/rtems-tools/config/rtems-version.ini:
> 0.not_r
> eleased: descriptor 'isdigit' requires a 'str' object but received a 'unicode'
Amar mentioned something about this in a chat the other day and I have not
chased it up.
Maybe he has something to add which could help?
Which version of python do you have installed?
> No idea about doxygen, but this is installed on the system I am using:
> [h1 at earth rtems-tools (master)]$ which doxygen
> /usr/bin/doxygen[h1 at earth rtems-tools (master)]$ doxygen
> error: Doxyfile not found and no input file specified!
> Doxygen version 1.8.13
> Copyright Dimitri van Heesch 1997-2015
> You can use doxygen in a number of ways:
Hmm I am not sure where this dependency on doxygen comes from.
