RTEMS tools invalid version file
    Amar Takhar
    amar at rtems.org
    Tue Oct 30 02:06:35 UTC 2018
On 2018-10-30 11:20 +1100, Chris Johns wrote:
<snip>
> Amar mentioned something about this in a chat the other day and I have not
> chased it up.
<snip>
This is quick since it's late but the issue I ran into is in
  rtemstoolkit/version.py
In line 174: -- if that's the latest
  _revision = int(''.join(itertools.takewhile(str.isdigit, rev)))
Depending on the version of Python you are running 'rev' can be unicode() or
str().  The operation being run is not valid for unicode.
The fix I did to solve this issue was to coerce it to str()
_revision = int(''.join(itertools.takewhile(str.isdigit, str(rev))))
This should be harmless since the value is always a string anyway so no data
will ever be lost.
Amar.
