problem in building BSP erc32
Mon Feb 1 19:32:57 UTC 2021
Hi Ayushman,
The 'master' branches default to the next version number for release. So
you would want to be using version 6, or else switch to version 5
explicitly.  For new development and getting involved with RTEMS we
recommend using the development versions.
I guess we need to fix that version number, we have this problem of version
numbers growing stale in the documentation.
Gedare
On Mon, Feb 1, 2021 at 12:28 PM Ayushman Mishra <ayushvidushi01 at gmail.com>
wrote:
> Hello everyone , I am Ayushman (chetak123) Btech 2nd year new to the
> RTEMS organization . I have installed  rtems5-sparc and trying to
> build BSP erc32
> (https://docs.rtems.org/branches/master/user/start/bsp-build.html) but
> I am getting BUILD FAIL while trying to do it using RSB and when doing
> it manually there was no waf or wscript file present in branch 5 of
> rtems git repository (in which I am currently working) , so downloaded
> waf executable and copied wscript along with yaml and spec/build
> directory from master branch into my working branch but now when I run
> ./waf configure --prefix=$HOME/quick-start/rtems/5  it starts looking
> for rtems6 instead of 5 (Could not find the program
> ['sparc-rtems6-gcc'] ) and I am really stuck here.
> I would be very thankful if somebody can please help me.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210201/771d2169/attachment.html>
