xilinx_zynq_a9_qemu RTEMS6 no console input/output
junkes junkes at fhi-berlin.mpg.de
Fri Feb 19 06:53:41 UTC 2021
Hello Christian,
I checked with gdb.
start with
sudo ~/QEMU/rtems/6/bin/qemu-system-arm -M xilinx-zynq-a9 -S -s -m 256M
-no-reboot -serial null -serial mon:stdio  -nographic -kernel
./arm-rtems6/c/xilinx_zynq_a9_qemu/testsuites/samples/fileio.exe
other terminal:
$ ~/QEMU/rtems/6/bin/arm-rtems6-gdb
GNU gdb (GDB) 10.1.90.20210205-git
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from
./arm-rtems6/c/xilinx_zynq_a9_qemu/testsuites/samples/fileio.exe...
(gdb) target rem localhost:1234
Remote debugging using localhost:1234
bsp_start_vector_table_end ()
     at
../../../../../../../../../kernel/c/src/lib/libbsp/arm/xilinx-zynq/../../../../../../bsps/arm/shared/start/start.S:192
192		mov	r0, #0
(gdb) c
Continuing.
                          <---- no output
^C
Program received signal SIGINT, Interrupt.
bsp_vector_table_begin ()
     at
../../../../../../../../../kernel/c/src/lib/libbsp/arm/xilinx-zynq/../../../../../../bsps/arm/shared/start/start.S:73
73		ldr	pc, .Lhandler_addr_undef
(gdb) bt
#0  bsp_vector_table_begin ()
     at
#1  0x0010481c in zynq_mmu_config_table ()
Backtrace stopped: previous frame identical to this frame (corrupt
stack?)
(gdb)
Same behavior on MVME2500 with RTEMS6:
VME2500=> run rtems_myTests
reading mvme2500.dtb
12363 bytes read in 13 ms (928.7 KiB/s)
Speed: 1000, full duplex
Using eTSEC1 device
TFTP from server 141.14.128.9; our IP address is 141.14.128.89
Filename 'ticker.img'.
Load address: 0x10000000
Loading: #####
          6.4 MiB/s
done
Bytes transferred = 60182 (eb16 hex)
WARNING: adjusting available memory to 30000000
## Booting kernel from Legacy Image at 10000000 ...
    Image Name:   RTEMS
    Created:      2021-02-18  20:18:21 UTC
    Image Type:   PowerPC Linux Kernel Image (gzip compressed)
    Data Size:    60118 Bytes = 58.7 KiB
    Load Address: 00004000
    Entry Point:  00004000
    Verifying Checksum ... OK
## Flattened Device Tree blob at 20000000
    Booting using the fdt blob at 0x20000000
    Uncompressing Kernel Image ... OK
    Loading Device Tree to 03ff9000, end 03fff04a ... OK
no further output ...
Will now try your install target ...
Heinz
On 2021-02-18 22:28, Christian Mauderer wrote:
> Hello Heinz,
> On 18/02/2021 21:38, junkes wrote:
>> Hallo Christian,
>> thank you for testing. This is "my procedure":
> hm. There doesn't seem to be a big difference to mine. If you are
> interested, take a look at the install target in the Makefile in:
> https://gitlab.com/c-mauderer/rtems-simulation-environment
> It's basically just building the same stuff. Differences:
> I use the waf based build system for the BSP. But that shouldn't
> really matter at the moment. But note that you might have to switch
> somewhen in the near future because it is planned to remove the old
> autoconf / automake based build system.
> Beneath that I use a qemu build from the upstream sorces because the
> version from RSB doesn't build cleanly on Arch Linux (something about
> docs). But I tried it with the binary build by RSB and that works too.
> I'll think a bit about it and let you know when I find something other
> that might be a problem. But at the moment, I'm running out of ideas.
> Maybe you can try to attach a gdb to your qemu and see whether the
> application runs and only doesn't produce output?
> Best regards
> Christian
>> ### Installation RTEMS6 / EPICS7 (xilinx_zynq_a9_qemu)
>> Installation RTEMS6 and EPICS 7 incl. rtems tools, kernel, bsp and
>> libbsd
>> ubuntu 20.04.1
>> **Installing rtems source builder and build rtems-powerpc tools**
>>      mkdir QEMU
>>      cd QEMU
>>      git clone https://github.com/RTEMS/rtems-source-builder.git rsb
>>      cd rsb
>>      git checkout master
>>      git pull
>>      cd rtems
>>      ../source-builder/sb-set-builder --prefix=$HOME/QEMU/rtems/6
>> 6/rtems-arm
>> RTEMS Source Builder - Set Builder, 6 (61dcadee0825)
>>   Command Line: ../source-builder/sb-set-builder
>> --prefix=/home/junkes/QEMU/rtems/6 6/rtems-arm
>>   Python: 2.7.18 (default, Aug  4 2020, 11:16:42) [GCC 9.3.0]
>> Build Set: 6/rtems-arm
>> Build Set: 6/rtems-autotools.bset
>> Build Set: 6/rtems-autotools-internal.bset
>> config: tools/rtems-autoconf-2.69-1.cfg
>> package: autoconf-2.69-x86_64-linux-gnu-1
>> script:  1: #!/bin/sh
>> script:  2: # ___build_pre as set up in defaults.py
>> script:  3: # Save the original path away.
>> script:  4: export SB_ORIG_PATH=${PATH}
>> script:  5: # Directories
>> script:  6: SB_PREFIX="/home/junkes/QEMU/rtems/6"
>> script:  7: SB_PREFIX_CLEAN=$(echo "/home/junkes/QEMU/rtems/6" |
>> /bin/sed -e 's/^\///')
>> script:  8: SB_SOURCE_DIR="/home/junkes/QEMU/rsb/rtems/sources"
>> script:  9:
>> SB_BUILD_DIR="/home/junkes/QEMU/rsb/rtems/build/autoconf-2.69-x86_64-linux-gnu-1"
>> script: 10: # host == build, use build; host != build, host uses host
>> and build uses build
>> installing: expat-2.1.0-x86_64-linux-gnu-1 ->
>> installing: gmp-6.1.0-x86_64-linux-gnu-1 -> /home/junkes/QEMU/rtems/6
>> installing: arm-rtems6-gdb-e1a808d-x86_64-linux-gnu-1 ->
>> installing: arm-rtems6-binutils-c0034ac-x86_64-linux-gnu-1 ->
>> installing: arm-rtems6-gcc-eb15f76-newlib-d4a756f-x86_64-linux-gnu-1
>> installing: rtems-tools-90342feb4dd63d188ce945adfb0a7694a42a65cd-1 ->
>> cleaning: expat-2.1.0-x86_64-linux-gnu-1
>> cleaning: gmp-6.1.0-x86_64-linux-gnu-1
>> cleaning: arm-rtems6-gdb-e1a808d-x86_64-linux-gnu-1
>> cleaning: arm-rtems6-binutils-c0034ac-x86_64-linux-gnu-1
>> cleaning: arm-rtems6-gcc-eb15f76-newlib-d4a756f-x86_64-linux-gnu-1
>> cleaning: rtems-tools-90342feb4dd63d188ce945adfb0a7694a42a65cd-1
>> Build Sizes: usage: 9.360GB total: 2.750GB (sources: 796.541MB,
>> patches: 66.634KB, installed 1.972GB)
>> installing: 6/rtems-arm -> /home/junkes/QEMU/rtems/6
>> clean staging: 6/rtems-arm
>> Staging Size: 5.291MB
>> Build Set: Time 0:34:44.211033
>> Build qemu-server:
>> --prefix=/home/junkes/QEMU/rtems/6 devel/qemu.bset
>> Add to $HOME/.bashrc:
>>      #RTEMS development
>>      export RTEMS_VERSION=6
>>      export RTEMS_ARCH=arm-rtems${RTEMS_VERSION}
>>      export RTEMS_BSP=xilinx_zynq_a9_qemu
>>      export RTEMS_ROOT=${HOME}/QEMU/rtems/${RTEMS_VERSION}
>>      export PATH=${RTEMS_ROOT}/bin:${PATH}
>>      export
>> RTEMS_MAKEFILE_PATH=${RTEMS_ROOT}/${RTEMS_ARCH}/${RTEMS_BSP}
>>      export RTEMS_SHARE_PATH=${RTEMS_ROOT}/share/rtems${RTEMS_VERSION}
>> **Installing rtems kernel and bootstrap**
>>      cd; cd QEMU
>>      git clone https://github.com/RTEMS/rtems.git kernel
>>      cd kernel;
>>      git checkout master
>>      git pull
>>      ./bootstrap -c && ./rtems-bootstrap
>> output:
>>   removing automake generated Makefile.in files
>> removing configure files
>> removing aclocal.m4 files
>> RTEMS Bootstrap, 1.0
>>        1/119: autoreconf: configure.ac
>>        2/119: autoreconf: testsuites/configure.ac
>>        3/119: autoreconf: testsuites/smptests/configure.ac
>>        4/119: autoreconf: testsuites/fstests/configure.ac
>>        5/119: autoreconf: testsuites/ada/configure.ac
>>        6/119: autoreconf: testsuites/benchmarks/configure.ac
>>        7/119: autoreconf: testsuites/libtests/configure.ac
>>        8/119: autoreconf: testsuites/rhealstone/configure.ac
>>        9/119: autoreconf: testsuites/psxtests/configure.ac
>>       10/119: autoreconf: testsuites/psxtmtests/configure.ac
>>       11/119: autoreconf: testsuites/sptests/configure.ac
>>       12/119: autoreconf: testsuites/mptests/configure.ac
>>       13/119: autoreconf: testsuites/samples/configure.ac
>>       14/119: autoreconf: testsuites/tmtests/configure.ac
>>       15/119: autoreconf: c/configure.ac
>>      110/119: autoreconf:
>> c/src/lib/libbsp/powerpc/mvme3100/configure.ac
>>      111/119: autoreconf:
>> c/src/lib/libbsp/powerpc/haleakala/configure.ac
>>      112/119: autoreconf:
>> c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac
>>      113/119: autoreconf:
>> c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac
>>      114/119: autoreconf: c/src/lib/libbsp/powerpc/qoriq/configure.ac
>>      115/119: autoreconf:
>> c/src/lib/libbsp/powerpc/gen5200/configure.ac
>>      116/119: autoreconf:
>> c/src/lib/libbsp/powerpc/qemuppc/configure.ac
>>      117/119: autoreconf: c/src/lib/libbsp/powerpc/virtex/configure.ac
>>      118/119: autoreconf:
>> c/src/lib/libbsp/powerpc/virtex4/configure.ac
>>      119/119: autoreconf: cpukit/configure.ac
>>      Bootstrap time: 0:00:27.754820
>>      cd; cd QEMU
>>      mkdir -p build/b-xilinx_zynq_a9_qemu/
>>      cd build/b-xilinx_zynq_a9_qemu/
>>      ../../kernel/configure --prefix=$HOME/QEMU/rtems/6
>> --target=arm-rtems6 --enable-rtemsbsp=xilinx_zynq_a9_qemu
>> --enable-posix --enable-c++ --disable-networking --enable-tests
>> config.log:
>>      This file contains any messages produced by compilers while
>>      running configure, to aid debugging if configure makes a mistake.
>>      It was created by rtems configure 6.0.0, which was
>>      generated by GNU Autoconf 2.69.  Invocation command line was
>>        $ ../../kernel/configure --prefix=/home/junkes/QEMU/rtems/6
>>      ## Platform. ##
>>      hostname = Krikkit
>>      uname -m = x86_64
>>      uname -r = 5.8.0-43-generic
>>      uname -s = Linux
>>      uname -v = #49~20.04.1-Ubuntu SMP Fri Feb 5 09:57:56 UTC 2021
>>      /usr/bin/uname -p = x86_64
>>      /bin/uname -X     = unknown
>>      make -j17 all
>>      make install
>> rtems-libbsd
>>      cd;cd QEMU
>>      cd rtems-libbsd
>>      git remote -v
>>      origin    https://github.com/RTEMS/rtems-libbsd.git (fetch)
>>      origin    https://github.com/RTEMS/rtems-libbsd.git (push)
>>      git checkout master
>>      git pull
>>      git checkout 6-freebsd-12
>>      git submodule init
>>      git submodule update rtems_waf
>>      ./waf configure --prefix=$HOME/QEMU/rtems/6
>> --rtems-bsps=arm/xilinx_zynq_a9_qemu --buildset=buildset/default.ini
>>      ./waf
>>      ./waf install
>> qemu-testing:
>> no ouptut and must be killed by other terminal:
>> $ qemu-system-arm -no-reboot -serial null -serial mon:stdio -net none
>> -nographic -M xilinx-zynq-a9 -m 256M -kernel
>> arm-rtems6/c/xilinx_zynq_a9_qemu/testsuites/samples/hello.exe
>> qemu-system-arm: warning: nic cadence_gem.0 has no peer
>> qemu-system-arm: warning: nic cadence_gem.1 has no peer
>> On 2021-02-18 21:10, Christian Mauderer wrote:
>>> Hello Heinz,
>>> Odd. I just tested it with the current master of rtems, libbsd, rtems
>>> source builder and qemu and it worked fine. The only thing that I had
>>> to change compared to your command was adding the "-serial null"
>>> before the second "-serial mon:stdio". Note that it's "null" and not
>>> "none" like for network. I made that mistake when trying to adapt
>>> your
>>> command line the first time and received no output.
>>> Beneath that I have an
>>>     export QEMU_AUDIO_DRV=none
>>> in my script that starts qemu. I'm not sure why and it seems that it
>>> is no longer necessary. But maybe you want to try it.
>>> If both don't help:
>>> Which version of rtems are you using and how do you configure your
>>> BSP? Which version of qemu are you using?
>>> On 18/02/2021 18:21, Heinz Junkes wrote:
>>>> Thanks, unfortunately I also have the same behavior with -serial
>>>> null -serial on:stdio.
>>>> So I use it with RTEMS5 which worked so far.
>>>> I had found this in the mail list and tried it ;-)
>>> The patch below seems to be for the xilinx_zynqmp* BSP and not for
>>> the
>>> xilinx_zynq_a9_qemu.
>>> Best regards
>>> Christian
>>>> Heinz
>>>> Qemu's machine definition uses the second UART in the memory map as
>>>> the
>>>> primary UART. This follows from the hardware itself where the second
>>>> UART in the memory map is UART 0. This switches the tester to using
>>>> the
>>>> correct UART.
>>>> tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini | 2 +-
>>>> tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini  | 2 +-
>>>> 2 files changed, 2 insertions(+), 2 deletions(-)
>>>> diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
>>>> b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
>>>> index 5ff0e86..35869ed 100644
>>>> --- a/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
>>>> +++ b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
>>>> @@ -35,4 +35,4 @@
>>>> bsp           = xilinx_zynqmp_ilp32
>>>> arch          = aarch64
>>>> tester        = %{_rtscripts}/qemu.cfg
>>>> -bsp_qemu_opts = %{qemu_opts_base} -serial null -serial mon:stdio
>>>> -machine xlnx-zcu102 -m 4096
>>>> +bsp_qemu_opts = %{qemu_opts_base} -serial mon:stdio -machine
>>>> xlnx-zcu102 -m 4096
>>>> diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
>>>> b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
>>>> index 8db82b6..cd2d268 100644
>>>> --- a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
>>>> +++ b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
>>>> @@ -35,4 +35,4 @@
>>>> bsp           = xilinx_zynqmp_lp64
>>>> arch          = aarch64
>>>> xlnx-zcu102 -m 4096
>>>> _______________________________________________
>>>> users mailing list
>>>> users at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/users
>> users mailing list
>> users at rtems.org
