Fw: xilinx_zynq_zc706 BSP
Siddons, David
siddons at bnl.gov
Tue May 25 14:23:45 UTC 2021
Hi,
After a long absence I decided to have another shot at RTEMS for Zynq devices. I chose the zc706 board. Installation using RSB went OK. Building the BSP seemed to go well until this error:
/home/peter/development/rtems/5.1/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/peter/development/rtems/5.1/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/neon/hard/libc.a(lib_a-init.o): in function `__libc_init_array':
/home/peter/development/rtems/rtems-source-builder-5.1/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/neon/hard/newlib/libc/misc/../../../../../../../../../gcc-7.5.0/newlib/libc/misc/init.c:40: undefined reference to `_init'
collect2: error: ld returned 1 exit status
make[5]: *** [Makefile:631: base_sp.exe] Error 1
make[5]: Leaving directory '/home/peter/development/kernel/xilinx_zynq_zc706/arm-rtems5/c/xilinx_zynq_zc706/testsuites/samples'
make[4]: *** [Makefile:663: samples] Error 2
make[4]: Leaving directory '/home/peter/development/kernel/xilinx_zynq_zc706/arm-rtems5/c/xilinx_zynq_zc706/testsuites'
make[3]: *** [Makefile:1342: testsuites] Error 2
make[3]: Leaving directory '/home/peter/development/kernel/xilinx_zynq_zc706/arm-rtems5/c/xilinx_zynq_zc706'
make[2]: *** [Makefile:822: all-recursive] Error 1
make[2]: Leaving directory '/home/peter/development/kernel/xilinx_zynq_zc706/arm-rtems5/c/xilinx_zynq_zc706'
make[1]: *** [Makefile:289: all-recursive] Error 1
make[1]: Leaving directory '/home/peter/development/kernel/xilinx_zynq_zc706/arm-rtems5/c'
make: *** [Makefile:410: all-recursive] Error 1
peter at peter-OptiPlex-7070:~/development/kernel/xilinx_zynq_zc706$
I am building on Ubuntu 20.04. Config.log is attached. Any suggestions?
Pete.
URL: <http://lists.rtems.org/pipermail/users/attachments/20210525/b3b26bce/attachment-0001.html>
Type: text/x-log
Desc: config.log
URL: <http://lists.rtems.org/pipermail/users/attachments/20210525/b3b26bce/attachment-0001.bin>
