doubts in new RTEMS Test framework
Sun Apr 19 21:18:43 UTC 2020
My advice in these situations is to look for an existing that that uses the
framework and see what it looks like in the source files and Makefile.am.
On Sun, Apr 19, 2020, 3:17 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> Hello everyone,
> I tried to implement the new RTEMS Test framework
> told in this mail
> https://lists.rtems.org/pipermail/devel/2020-April/059203.html
> to pthread_getcpuclockid test suite as Dr Joel suggested
> https://lists.rtems.org/pipermail/devel/2020-April/059466.html
> But the terminal flashes the error when I replace POSIX_init with
> T_TEST_CASE()
> psxgetcpuclockid01/psxgetcpuclockid01-init.o:(.sdata2._POSIX_Threads_User_thread_table+0x0):
> undefined reference to `POSIX_Init'
> and when I remove
> #define CONFIGURE_POSIX_INIT_THREAD_TABLE
> Then it shows the error
>   #error "You must define one of
> CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION,
> CONFIGURE_RTEMS_INIT_TASKS_TABLE, and CONFIGURE_POSIX_INIT_THREAD_TABLE"
> which option would be selected in the case and what other changes would be
> required
> Thanks :)
> -Eshan
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200419/1f68c163/attachment.html>
