Using RTEMS on Zynq ultrascale in 32bit mode
Mingyu Li lmy2010lmy at gmail.com
Fri Oct 12 02:19:44 UTC 2018
Hi Jan,
RTEMS master currently supports ARM Xilinx Zynq:
https://github.com/RTEMS/rtems/tree/master/bsps/arm/xilinx-zynq.
Please have a look at
https://docs.rtems.org/branches/master/cpu-supplement/arm.html.
To understand the BSP framework, refer to
https://docs.rtems.org/branches/master/bsp-howto/index.html.
Hope it helps.
Best regards,
Maxul Lee
<Jan.Sommer at dlr.de> 于2018年10月10日周三 上午4:56写道:
> Hello,
> we will have access to a Xilinx Zynq ultrascale+ soon.
> It has 4xA53 cores.
> If I understand it correctly they are based on AArch64 which is currently
> not supported by RTEMS.
> However, running the processors in 32bit mode would be sufficient.
> I have some problems determining what is already present in RTEMS for a
> BSP.
> Has by any chance someone already done that?
> I only started to look at the RM of the SoC and try to determine which
> core devices have changes and need new/updated drivers in the shared arm
> directory.
> Any guidance would be greatly appreciated. Is it the right idea to start
> with the A9-based BSPs and go from there?
> Best regards,
>    Jan
> Deutsches Zentrum für Luft- und Raumfahrt e. V. (DLR)
> German Aerospace Center
> Simulation and Software Technology | Software for Space Systems and
> Interactive Visualization | Lilienthalplatz 7 | 38108 Braunschweig | Germany
> Jan Sommer
> Telephone +49 531 295-2494 | Telefax 0531 295-2767 | jan.sommer at dlr.de
> DLR.de/SC
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20181012/ce1f10f3/attachment-0002.html>
